Author Topic: Increment Challenge..  (Read 8452 times)
Marc'Antonio Alessi
  • Marco
Re: Increment Challenge..
« Reply #15 on: September 08, 2016, 04:16:49 PM »
this is my quick attempt..
Working with negative value and Upper or lower case :smitten:
Comando: (AA:SETCAR "A" -1)
Traccia all'indietro:
[0.50] (VL-BT)
[1.46] (ERRDUMP "valore dell'argomento errato: non negativo: -1")
[2.41] (_call-err-hook #<SUBR @000000002bff3f48 ERRDUMP> "valore dell'argomento errato: non negativo: -1")
[3.35] (sys-error "valore dell'argomento errato: non negativo: -1")
:ERROR-BREAK.30 nil
[4.27] (NTH -1 ("A" "B" "C" "D" "E" "F" "G" "H" "I" "J" "K" "L" "M" "N" "O" "P" "Q" "R" "S" "T" "U" "V" "W" "X" "Y" "Z"))
[5.21] (AA:SETCAR "A" -1)
[6.15] (#<SUBR @000000002bf8f2a0 -rts_top->)
[7.12] (#<SUBR @00000000353c8700 veval-str-body> "(AA:SETCAR \"A\" -1)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
Marc'Antonio Alessi
  • Marco
« Reply #16 on: September 08, 2016, 04:18:55 PM »
Test Made:
(ALE_ZetaStrIncVal "aa" -1)   = "a`"   I think it must be "z"  ?
Why? See your Reply #4 on: Today at 03:54:31 »
Marc'Antonio Alessi
  • Marco
« Reply #17 on: September 08, 2016, 04:29:42 PM »
Comando: (ALE_ZetaStrIncVal "aa" -1) > "a`"
Comando: (incsuff "aa" -1 7)              > "a`"
Comando: (ALE_ZetaStrIncVal "aB" 1)  > "aC"
Comando: (incsuff "aB" 1 7)            > "aC"
Andrea
« Reply #18 on: September 12, 2016, 01:32:21 PM »
Test Made:
..x...y...z...aa...ab...ac...ad  ?
so (aa - 1) must be "z"  ?
forse mi sbaglio ?
Keep smile...
« Reply #19 on: September 12, 2016, 06:35:42 PM »
I found a bug with my function  :oops: :
  1. _$ (LM:incalpha "Y" 1)
  2. "@"
The following should fix it and allow for lowercase:
  1. ;; Increment Alpha  -  Lee Mac
  2. ;; Increments an uppercase alphabetical string by a given number of units, e.g. AX + 4 = BB
  3. ;; a - [str] alphabetical string
  4. ;; i - [int] integer increment
  5.
  6. (defun LM:incalpha ( a i / c n )
  7.     (cond
  8.         (   (zerop i) a)
  9.         (   (zerop (setq n (strlen a)))
  10.             (LM:incalpha "A" (1- i))
  11.         )
  12.         (   (= 90 (logand 90 (setq c (ascii (substr a n)))))
  13.             (LM:incalpha (strcat (LM:incalpha (substr a 1 (1- n)) 1) (chr (boole 6 27 c))) (1- i))
  14.         )
  15.         (   (setq i (+ i (boole 4 97 c)))
  16.             (strcat (LM:incalpha (substr a 1 (1- n)) (/ i 26)) (chr (boole 7 (boole 1 96 c) (1+ (rem i 26)))))
  17.         )
  18.     )
  19. )
Jeff H
« Reply #20 on: September 12, 2016, 07:17:51 PM »
Can I borrow a dollar gile?
Merci Andrea,
This routine has been used as base routine in the "Increment" LISP suite which is the ancestor of the quite popular .NET "Increment" plugin on Exchange Apps.
Use it and a great tool
Marc'Antonio Alessi
  • Marco
« Reply #21 on: September 13, 2016, 02:48:59 AM »
Test Made:
forse mi sbaglio ?
Non so se ti sbagli ma tutte queste funzioni danno lo stesso risultato:
(LM:incalpha "aa" -1)       => "a`"
(ALE_ZetaStrIncVal "aa" -1) => "a`"
(incsuff "aa" -1 7)         => "a`"
VovKa
  • Ukraine
« Reply #22 on: September 13, 2016, 04:56:25 AM »
i think that doing math on the system that has no "zero" is not a good idea
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #23 on: September 13, 2016, 07:27:17 AM »
  2. "@"
  5.
  7.     (cond
  8.         (   (zerop i) a)
  11.         )
  14.         )
  17.         )
  18.     )
  19. )
(LM:incalpha  "D" 1);==>>"F"
(LM:incalpha  "d" 1);==>>"f"
« Reply #24 on: September 13, 2016, 08:14:48 AM »
Thanks - I had taken the binary manipulation a step too far  :oops:
Corrected (hopefully!):
  5.
  7.     (cond
  8.         (   (zerop i) a)
  11.         )
  14.         )
  15.         (   (setq i (+ i -1 (boole 4 96 c)))
  17.         )
  18.     )
  19. )
« Reply #25 on: September 13, 2016, 08:20:20 AM »
I may be speaking too soon, but I think the function could actually be condensed to:
  5.
  7.     (cond
  8.         (   (zerop i) a)
  9.         (   (zerop (setq n (strlen a))) (LM:incalpha "A" (1- i)))
  10.         (   (setq c (ascii (substr a n))
  11.                   i (+ i -1 (boole 4 96 c))
  12.             )
  13.             (strcat (LM:incalpha (substr a 1 (1- n)) (/ i 26)) (chr (boole 7 (boole 1 96 c) (1+ (rem i 26)))))
  14.         )
  15.     )
  16. )
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #26 on: September 13, 2016, 09:00:18 AM »
my version:
  1. (defun ai (s i / A B L)
  2.   (setq l (strlen s)
  3.             a (ascii (substr s l))
  4.             b (cond ((< 64 a 91) 64)
  5.                     ((< 96 a 123) 96)
  6.               )
  7.       )
  8.   (and (minusp i)(<(- a (abs i) b)1) (setq i (+ 26  i (/ i -26))))
  9.   (if b
  10.     (strcat (substr s 1 (1- l))
  11.             (cond ((< (+ b 26) (+ i a)) (chr (+ b (/ (- (+ i a) b) 26))))
  12.                   ("")
  13.             )
  14.             (chr (+ b ((lambda(c)(if (zerop c) 26 c)) (rem  (- (+ i a) b) 26))))
  15.     )
  16.   )
  17. )
test:
(ai  "A" 1) ;;>>> "B"
(ai  "D" 3) ;;>>> "G"
(ai  "AAP" 1) ;;>>> "AAQ"
(ai  "BAU" 2) ;;>>> "BAW"
(ai  "A" -1) ;;>>> "Z"
(ai  "FFFC" 2) ;;>>> "FFFE"
(ai  "Z" 1) ;;>>> "AA"
(ai  "Z" -1) ;;>>> "Y"
(ai  "a" 1) ;;>>> "b"
(ai  "d" 3) ;;>>> "g"
(ai  "aap" 1) ;;>>> "aaq"
(ai  "bau" 2) ;;>>> "baw"
(ai  "a" -1) ;;>>> "z"
(ai  "fffc" 2) ;;>>> "fffe"
(ai  "z" 1) ;;>>> "aa"
(ai  "z" -1) ;;>>> "y"
(ai  "y" -1) ;;>>> "x"
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #27 on: September 13, 2016, 09:03:36 AM »
(ai  "AA" -1) ;;>>> "AZ"
(ai  "zz" 1) ;;>>> "zaa"
« Last Edit: September 13, 2016, 09:11:22 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: September 13, 2016, 12:07:38 PM »
new variant:
  1. (defun ff (s i / b f)
  2.   (defun f (l i)
  3.     (cond ((= 0 i) l)
  4.           ((not l) (f (list i) 0))
  5.           ((cons (rem (+ (car l) i) 26) (f (cdr l) (/ (+ (car l) i) 26))))
  6.     )
  7.   )
  8.   (if (setq b (cond ((< 64 (ascii s) 91) 64)
  9.                     ((< 96 (ascii s) 123) 96)
  10.               )
  11.       )
  12.            (mapcar (function (lambda (a)
  13.                                (cond ((< a 1) "")
  14.                                      ((chr (+ a b)))
  15.                                )
  16.                              )
  17.                    )
  18.                    (reverse (f (reverse (mapcar (function (lambda (a) (- a 96))) (vl-string->list (strcase s t)))) i))
  19.            )
  20.     )
  21.   )
  22. )
test:
(ff "aa" -200);;>>> ""
(ff "aa" 200);;>>> "hs"
(ff "aa" 2000);;>>> "byy"
(ff "aa" -2000);;>>> ""
(ff "AA" -200) ;;>>> ""
(ff "AA" 200);;>>> "HS"
(ff "aA" -200) ;;>>> ""
(ff "aA" 200);;>>> "hs"
(ff "Aa" -200) ;;>>> ""
(ff "Aa" 200);;>>> "HS"
(ff  "AA" -1) ;;>>> "A"
(ff  "A" 1) ;;>>> "B"
(ff  "A" -1) ;;>>> ""
(ff  "D" 3) ;;>>> "G"
(ff  "AAP" 1) ;;>>> "AAQ"
(ff  "BAU" 2) ;;>>> "BAW"
(ff  "FFFC" 2) ;;>>> "FFFE"
(ff  "Z" 1) ;;>>> "AA"
(ff  "Z" -1) ;;>>> "Y"
(ff  "a" 1) ;;>>> "b"
(ff  "d" 3) ;;>>> "g"
(ff  "aap" 1) ;;>>> "aaq"
(ff  "bau" 2) ;;>>> "baw"
(ff  "a" -1) ;;>>> ""
(ff  "fffc" 2) ;;>>> "fffe"
(ff  "z" 1) ;;>>> "aa"
(ff  "z" -1) ;;>>> "y"
(ff  "y" -1) ;;>>> "x"
Marc'Antonio Alessi
  • Marco
« Reply #29 on: September 13, 2016, 12:51:06 PM »
 :-) IM(very)HO is a good solution... but the new question:
(ff "b"   -1) =>  "a"
(ff "aa"  -1) => "a"
Is it acceptable the same result on two strings? Perhaps VovKa said something right?
