Author Topic: Increment Challenge..  (Read 8406 times)
Andrea
« on: September 07, 2016, 05:02:13 PM »
Hi All,..
for any who are interested to this challenge..
The function must increment Alphabetic value with two (2) parameter...
ex: (AphaIncrement  A B)
A= Start Letter as a string
B= Increment value as integer (this can be also negative value)
So the challenge is this...
(AphaIncrement  "A" 1) = "B"
(AphaIncrement  "D" 3) = "G"
(AphaIncrement  "AAP" 1) = "AAQ"
(AphaIncrement  "BAU" 2) = "BAW"
(AphaIncrement  "A" -1) = "Z"
(AphaIncrement  "FFFC" 2) = "FFFE"
the goal is to have,...
a,b,c,d,e,....z,
aa,ab,ac,ad,ae...az,
ba,bc,bd,be,..bz
ca,cb,cd,ce,...cz,..
etc...
$5 for who can make this....
Get ready !...
this challenge will start NOW !
Good luck !  :knuppel2:
Keep smile...
VovKa
  • Ukraine
Re: Increment Challenge..
« Reply #1 on: September 07, 2016, 05:20:25 PM »
are you sure about this one?
« Reply #2 on: September 07, 2016, 06:04:21 PM »
« Reply #3 on: September 07, 2016, 06:52:22 PM »
Should've held out for a sammich.
Andrea
« Reply #4 on: September 07, 2016, 09:54:31 PM »
You're right....no sense..it must be nil or "A"
+1
« Last Edit: September 07, 2016, 09:58:53 PM by Andrea »
Keep smile...
Andrea
« Reply #5 on: September 07, 2016, 09:57:08 PM »
http://lee-mac.com/columnreference.html#incalpha
LEE !!!!!!!!!!!!!!   that's sick !  4 recursive in row !?
you're just amazing.. :uglystupid2:
one thing....your code do not allow negative value..as increment.
Keep smile...
roy_043
  • BricsCAD 18
« Reply #6 on: September 08, 2016, 03:24:08 AM »
+1
You need a representation for zero. If "A" is the first digit it follows that it represents zero. But this is counterintuitive. And if "A" is zero then "AA" is zero as well.
VovKa
  • Ukraine
« Reply #7 on: September 08, 2016, 05:12:19 AM »
i believe Lee's code is written to deal with MS Excel, so it's got no zero
VovKa
  • Ukraine
« Reply #8 on: September 08, 2016, 05:42:04 AM »
i have this to work with custom "numeral" systems based on positional notation
no negative numbers
(defun vk_AlphaBet2Dec (ABC AlphaBet / Len)
  (setq Len (strlen AlphaBet))
  (if (/= ABC "")
    (+ (* (expt Len (1- (strlen ABC)))
  (vl-string-position (ascii (substr ABC 1 1)) AlphaBet)
       (vk_AlphaBet2Dec (substr ABC 2) AlphaBet)
    0
(defun vk_Dec2AlphaBet (Dec AlphaBet / Len)
  (if (< Dec Len)
    (substr AlphaBet (1+ Dec) 1)
    (strcat (vk_Dec2AlphaBet (/ Dec Len) AlphaBet)
    (substr AlphaBet (1+ (rem Dec Len)) 1)
(vk_Dec2AlphaBet 35 "01")
(vk_Dec2AlphaBet 35 "0123456789")
(vk_Dec2AlphaBet 35 "0123456789ABCDEF")
(vk_Dec2AlphaBet 35 "ABCDEFGHIJKLMNOPQRSTUVWXYZ")
(vk_Dec2AlphaBet 35 "Aa")
(vk_Dec2AlphaBet 35 "theSwamp")
gile
  • Marseille, France
« Reply #9 on: September 08, 2016, 07:41:17 AM »
Quite a long time since I've been here...
You can see the (quite old too) topic.
Marc'Antonio Alessi
  • Marco
« Reply #10 on: September 08, 2016, 08:17:32 AM »
(defun ALE_ZetaStrIncVal (ZetStr IncVal / SttStr SttLen)
  (if (eq "" (setq SttStr (vl-string-right-trim "Z" ZetStr)))
    (strcat (vl-string-translate "Z" "A" ZetStr) "A")
    (strcat
      (substr SttStr 1 (setq SttLen (1- (strlen SttStr))))
      (chr (+ IncVal (vl-string-elt SttStr SttLen)))
      (if (eq ZetStr SttStr)
        (vl-string-translate "Z" "A" (substr ZetStr (+ 2 SttLen)))
(ALE_ZetaStrIncVal  "A" 1) "B"
(ALE_ZetaStrIncVal  "D" 3) "G"
(ALE_ZetaStrIncVal  "AAP" 1) "AAQ"
(ALE_ZetaStrIncVal  "BAU" 2) "BAW"
(ALE_ZetaStrIncVal  "A" -1) "@"  <<<<<<<<<<<<<<<<<
(ALE_ZetaStrIncVal  "FFFC" 2) "FFFE"
Andrea
« Reply #11 on: September 08, 2016, 10:06:38 AM »
this is my quick attempt..
Working with negative value and Upper or lower case :smitten:
(defun AA:setcar (startwith increment / carpref iba_alphabet cval str# startwith2 nextcar newstartwith)
  (setq startwith2 startwith)
  (if (< (ascii (substr startwith 1 1)) 96)
    (setq cval 64)
    (setq cval 96)
  (setq iba_alphabet nil)
  (repeat 26
    (setq iba_alphabet (append iba_alphabet (list (chr (setq cval (1+ cval))))))
  (setq carpref "")
  (if (> (setq str# (strlen startwith2)) 1)
    (progn (setq carpref (substr startwith2 1 (1- str#)))
           (setq startwith2 (substr startwith2 str#))
  (if (not
        (setq nextcar (nth (+ increment (vl-position startwith2 iba_alphabet))
                           iba_alphabet
    (progn (setq carpref startwith)
           (setq nextcar startwith2)
  (setq newstartwith (strcat carpref nextcar))
Keep smile...
Andrea
« Reply #12 on: September 08, 2016, 10:17:53 AM »
Well,...you guys are just amazing..
many concept, diffrent thinking remind me how human can be intelligent sometime.
Thank you very much for sharing all these samples and knowledge.
Now,..who is the winner of this 5$ ?   :whistling:
Keep smile...
Andrea
« Reply #13 on: September 08, 2016, 11:06:51 AM »
Test Made:
(ALE_ZetaStrIncVal "aa" -1)   = "a`"   I think it must be "z"  ?
(LM:incalpha "a" 1)  = "AH"  ?   lowercase ?
(incsuff "aB" 1 7) = work perfectly
(aa:setcar "BB" -1)  = "BA"
(aa:setcar "BA" -1) = Error  :)
so,.....GILE is the winner !
Also,..his code allow numeric value and respect CASE sensitive..
nice coding GILE.  merci.
Keep smile...
gile
  • Marseille, France
« Reply #14 on: September 08, 2016, 02:29:13 PM »
Merci Andrea,
This routine has been used as base routine in the "Increment" LISP suite which is the ancestor of the quite popular .NET "Increment" plugin on Exchange Apps.
