Author Topic: window or crossing selection within a hatch  (Read 2273 times)
ZNETQ
« on: June 26, 2013, 02:17:14 AM »
(see image inline,  ** edit: for the guests of this forum, you can see the image @ http://prelem.com/hat.png )
I'm trying to select the 3 plines sitting inside the big blue solid hatch in one go by window or crossing selection.
There is no way to select any other object that the hatch itself if I start the selection from a point located inside the hatch boundaries. By contrast, the selection works fine if I start the selection window outside the hatch
Is this the standard behavior or am I missing something ? Is there a system variable involved with that behavior ?
Running vanilla acad2012 fullversion, PICKFIRST 1, PICKSTYLE 0
« Last Edit: June 26, 2013, 03:31:33 AM by ZNETQ »
Rob...
Re: window or crossing selection within a hatch
« Reply #1 on: June 26, 2013, 06:28:05 AM »
Can you select them by picking?
CAD Tech
ZNETQ
« Reply #2 on: June 26, 2013, 07:32:34 AM »
Thanks for your reply
Yes, selecting each pline by picking works
Not what I'm trying to achieve though
Rob...
« Reply #3 on: June 26, 2013, 07:37:46 AM »
I understand. I just wanted to make sure that they were selectable. I cannot recreate the problem. Can you post a file? Maybe not, as you are new here but give it a try.
CAD Tech
ZNETQ
« Reply #4 on: June 26, 2013, 07:40:19 AM »
sure, you should see the dwg attached
Rob...
« Reply #5 on: June 26, 2013, 07:52:08 AM »
I didn't fully read your post earlier. Not quite awake at that time. That is normal behavior. I thought there was a variable for hatches to be selectable only at the boundary, similar to images, but can't find it at the moment.
CAD Tech
ZNETQ
« Reply #6 on: June 26, 2013, 08:03:23 AM »
thanks for taking the time to answer Rob !
Rob...
« Reply #7 on: June 26, 2013, 08:06:02 AM »
No problem. If I can verify that that setting exists, I'll be back.
CAD Tech
