Author Topic: How to run a lisp when close file ?  (Read 17047 times)
kruuger
Re: How to run a lisp when close file ?
« Reply #15 on: May 31, 2012, 04:26:02 AM »
Glad to help, though I fear we've led you to the dark side. If you think you've made errors before, wait till you've made an error in reactors  :lmao: ... they're DANGEROUS beyond belief!
So true.. Dangerous reactor is.
@hasanCAD/kruuger
Think about this. what are the conditions as when to trigger the lisp routine? Every time the user invoke a save* command? in the event the user saves the file and continues working on the file?
after a while the user click save again, then that will be two Filehistory lines. You may need to use a counter within the lisp code to determine that it ran at least once, then it should the repalce the string rather than writing a new line.
_close reator is indeed the way to go
i'm using this reactor to save info about user who modify the file.
after few days of work i have nice history in DICTIONARY
of course i can review with separate program
this is what you want HasanCAD ?
kruuger
Coder
« Reply #16 on: May 31, 2012, 04:41:26 AM »
Why not include command CLOSE at the bottom of the routine and exclude using reactors .... :pissed:
kruuger
« Reply #17 on: May 31, 2012, 04:45:43 AM »
and how to run program to save history on close without reactor ?
kruuger
irneb
« Reply #18 on: May 31, 2012, 04:54:48 AM »
You could undefine the close command, then your defun would be named c:close and inside it you call "._CLOSE" to run the "undefined" command.
Or use the vla-Close on the current document rather. Also you might then have to implement some sort of "Do you want to save changes" dialog. Personally I agree with this idea more, there's less to go wrong, and you've got more control over what's happening.
kruuger
« Reply #19 on: May 31, 2012, 05:10:59 AM »
probably should work. i don't know how close reactor but save works very well. i;m working with this routine over 2 years with 40 people.
there was not a single problem. history are always in drawings
kruuger
Coder
« Reply #20 on: May 31, 2012, 06:24:47 AM »
kruuger
I mean when the user run the code , the text would be created and the command close would close the drawing .
HasanCAD
« Reply #21 on: May 31, 2012, 07:18:48 AM »
kruuger
YES this is what I want
pBe
« Reply #22 on: May 31, 2012, 09:44:52 AM »
kruuger
Nice idea,
Will that be separate Dictionary for each drawing file on an external file? does it keep a record on the drawing itself?
BlackBox
« Reply #23 on: May 31, 2012, 10:11:28 AM »
Thanks pBe I'll study yours
I guess the best way to do that is via reactor
How is this?
I do not know whats reactor.
  1. (Defun AtSaveCommand (calling-reactor b)
  2.   (if
  3.     (or
  4.       (= (car b) "QSAVE")
  5.       (= (car b) "SAVEAS")
  6.       (= (car b) "SAVE")
  7.     )
  8.     (C:SLOWNIK)
  9.   )
  10. )
  11.
  12. (Defun loadTheSaveReactor ()
  13.   (if *FileOnSave* (vlr-remove *FileOnSave*))
  14.   (setq *FileOnSave* (vlr-command-reactor nil '((:vlr-commandwillStart . AtSaveCommand))))
  15. )
  16.
  17. (loadTheSaveReactor)
i'm using this when someone save the drawing. works very well.
easy to modify to CLOSE.
kruuger
FWIW - I've always preferred the OR function when calls may be made more than once within a Defun (I've also used Cond as needed):
  1.
  2.
  3.
  4. ;;;--------------------------------------------------------------------;
  5. ;;; Reactors:Start function
  6. (defun Reactors:Start  ()
  7.
  8.   ;; Command reactors
  9.   (or *Reactors_Command*
  10.       (setq *Reactors_Command*
  11.              (vlr-command-reactor
  12.                nil
  13.                '((:vlr-commandCancelled . Callback:CommandEnded)
  14.                  (:vlr-commandEnded . Callback:CommandEnded)
  15.                  (:vlr-commandFailed . Callback:CommandEnded)
  16.                  (:vlr-commandWillStart . Callback:CommandWillStart)))))
  17.
  18.   ;; <- Other reactors (i.e., AcDb, DocManager, Editor, Object, etc.
  19.
  20.   (prompt "\n \n  >>  Reactors Loaded ")
  21.   (princ))
  22. ;;;--------------------------------------------------------------------;
  23. ;;; Callback:CommandEnded function
  24. (defun Callback:CommandEnded  (rea cmd / cmdName)
  25.   (cond
  26.     ((wcmatch (setq cmdName (car cmd))
  27.               "COPY,GRIP_STRETCH,MOVE,SCALE,STRETCH")                   ; Cursorsize
  28.      (progn
  29.        (setvar 'cursorsize *Reactor_CursorSize*)
  30.        (setq *Reactor_CursorSize* nil)))
  31.
  32.     ((wcmatch (setq cmdName (car cmd)) "**SAVE*")                       ; Save
  33.      (c:SlowNik))
  34.
  35.     ((and capslock
  36.           (wcmatch cmdName
  37.                    "BLOCK,*EDIT*,*TEXT*,*LAYERSTATE*,*LEADER*"))        ; Text edits
  38.
  39.      ;; Restore original capslock setting
  40.      (capslock *Reactor_CapsLock*)
  41.      (setq *Reactor_CapsLock* nil))
  42.
  43.     ;; <- Other commands
  44.
  45.     ))
  46. ;;;--------------------------------------------------------------------;
  47. ;;; Callback:CommandWillStart function
  48. (defun Callback:CommandWillStart  (rea cmd / cmdName)
  49.   (cond ((wcmatch (setq cmdName (car cmd))
  50.                   "COPY,GRIP_STRETCH,MOVE,SCALE,STRETCH")               ; Cursorsize
  51.          (progn
  52.            (setq *Reactor_CursorSize* (getvar 'cursorsize))
  53.            (setvar 'cursorsize 100)))
  54.
  55.         ((wcmatch cmdName "**SAVE*")                                    ; Save
  56.          (c:SlowNik))
  57.
  58.         ((and capslock
  59.               (wcmatch cmdName
  60.                        "*BLOCK,*EDIT*,*TEXT*,*LAYERSTATE*,*LEADER*"))   ; Text edits
  61.
  62.          ;; Store original capslock setting, and turn capslock on
  63.          (setq *Reactor_CapsLock* (capslock))
  64.          (capslock T))
  65.
  66.         ;; <- Other commands
  67.
  68.         ))
  69. ;;;--------------------------------------------------------------------;
  70. (Reactors:Start)
  71.
... A few extra goodies are included, free of charge. LoL :kewl:
« Last Edit: June 29, 2012, 04:36:49 PM by RenderMan »
kruuger
« Reply #24 on: May 31, 2012, 06:35:18 PM »
kruuger
Nice idea,
i store user info only in drawing:
  1. UserHistory [under named object dictionary]
  2. |
  3. |---Item_1 (xrecord)
  4. |---Item_2 (xrecord)
  5. |---Item_3 (xrecord)
but this can be very easy save to file
kruuger
please find attached files and make a test.
the coding is TERRIBLE. maybe it is time to rewrite this mess  :|
load all files. after save command type AUTOR to see the dwg log.
k.
HasanCAD
« Reply #25 on: June 03, 2012, 03:37:47 AM »
I like every think if is free  :-D
HasanCAD
« Reply #26 on: June 03, 2012, 03:56:58 AM »
YES it is
You know when I read these 2 replies
http://docs.autodesk.com/ACD/2011/ENU/filesALG/WS73099cc142f4875516d84be10ebc87a53f-7c34.htm
and
http://docs.autodesk.com/ACD/2011/ENU/filesALR/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-67b0.htm
and
Also from the same website you used for reference on you code:
http://www.afralisp.net/visual-lisp/tutorials/reactors-part-1.php
My feeling was that both of us on a boat and you pushed me in the sea and said " teach yourself the swimming"
HasanCAD
« Reply #27 on: June 03, 2012, 04:43:45 AM »
That perfect
but when open, save and close the file gives me one line in history
kruuger
« Reply #28 on: June 03, 2012, 06:59:03 PM »
That perfect
if one person is working on file, there is only one line per day. each save replace only time.
when someone else save the dwg program add them to history.
if file back to you program will "catch you" again.
is this clear ?
rewritten AUTOR.LSP to LOG.LSP (new shortcut LOG)
added option to sort columns.
dcl file is created on the fly (Save login.dcl not required)
kruuger
BlackBox
« Reply #29 on: June 03, 2012, 08:28:41 PM »
What is to prevent the user from opening the drawing, and doing nothing for several hours and saving the drawing (effectively producing nothing). Won't their time still be logged?
Perhaps it would be prudent to incorporate a Sysvar Reactor that monitors Cmdactive, and when commands are not active, the timer is prgramatically stopped. Just a thought, as this thread somewhat reminds me an AUGI thread about CadTempo.
