It can be integrated in VS 2005 - very useful thing!
I've not tested but think that it can be integrated in VS 2005 Express Edition too.
Pardon my ignorance, but how would you go about doing that?
When I go to install it. It says that it needs the .Net framework 2.0, which my company doesn't want me to install right now, will it work with 1.1? I'm hesitant to install, so if you say it will, then I will.Thanks for the help.
Quote from: T.Willey on July 31, 2006, 05:00:52 PMWhen I go to install it. It says that it needs the .Net framework 2.0, which my company doesn't want me to install right now, will it work with 1.1? I'm hesitant to install, so if you say it will, then I will.Thanks for the help.This help file is based on AutoCAD 2007 .NET API (AutoCAD 2007 is based on .NET 2.0). Many of objects and methods are not implemented in AutoCAD 2005-2006 .NET API (which based on .NET 1.1)
Does this mean I can't really use this? do I have to wait till I get 2007?
