Author Topic: (AutoCAD) Help file for .NET?  (Read 13308 times)
« on: July 21, 2006, 05:23:22 PM »
Is there a help file for .NET (C#) like the VBA and ActiveX one that comes with AutoCAD.  I have one from ObjectARX, but it doesn't break it down like the other one does.
Thanks in advance.
Re: (AutoCAD) Help file for .NET?
« Reply #1 on: July 21, 2006, 05:41:06 PM »
I think I found what I'm looking for here.
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #3 on: July 31, 2006, 11:18:10 AM »
Thanks.  I downloaded it.  Will look at it when I get some time to play.
Alexander Rivilis
« Reply #4 on: July 31, 2006, 01:39:30 PM »
It can be integrated in VS 2005 - very useful thing! :)
« Reply #5 on: July 31, 2006, 02:05:33 PM »
You have to buy that though, right?  I only program for fun right now, so I can't get my company to pay for it.  Will it work with the express version? or anyother free ide?  Thanks again.
Alexander Rivilis
« Reply #6 on: July 31, 2006, 03:57:01 PM »
I've not tested but think that it can be integrated in VS 2005 Express Edition too.
« Reply #7 on: July 31, 2006, 03:58:48 PM »
Thanks.  Maybe I will dl it and give it a go.
Alexander Rivilis
« Reply #8 on: July 31, 2006, 04:21:01 PM »
Now I've tested this help file with SharpDevelop IDE. It's OK! You need select menu Tools->Options->Tools->Help 2.0 Environment->ObjectARX Reference For DOTNET
Dave R
« Reply #9 on: July 31, 2006, 04:25:03 PM »
Pardon my ignorance, but how would you go about doing that?
Alexander Rivilis
« Reply #10 on: July 31, 2006, 04:42:23 PM »
In any browser (for example: Internet Explorer) type: ms-help://MS.VSCC.v80/dv_vscccommon/local/CollectionManager.htm
Select ObjectARX Reference For .NET and Update VSCC
« Reply #11 on: July 31, 2006, 05:00:52 PM »
When I go to install it.   It says that it needs the .Net framework 2.0, which my company doesn't want me to install right now, will it work with 1.1?  I'm hesitant to install, so if you say it will, then I will.
Thanks for the help.
Alexander Rivilis
« Reply #12 on: July 31, 2006, 05:12:01 PM »
This help file is based on AutoCAD 2007 .NET API (AutoCAD 2007 is based on .NET 2.0). Many of objects and methods are not implemented in AutoCAD 2005-2006 .NET API (which based on .NET 1.1)
« Reply #13 on: July 31, 2006, 05:18:20 PM »
Does this mean I can't really use this? do I have to wait till I get 2007?
Thanks again for all your help.
Alexander Rivilis
« Reply #14 on: July 31, 2006, 05:29:17 PM »
You can using this help with AutoCAD 2005...2006 but need to compare help topic's with information from Object Browser in order to proper using of classes and methods. Not to wonder if you see that some classes in general not present in previous versions of AutoCAD.
« Last Edit: July 31, 2006, 05:50:50 PM by Rivilis »
