Author Topic: Point Elevations Labels displaying incorrectly.  (Read 3370 times)
DPATTERSON
« on: November 27, 2014, 03:31:49 PM »
Alright... I have no idea with this one but maybe one of you guys do.
So I am importing a point list from a text file into Civil 3D.  Units are in meters, the point list is fine and has no errors, everything is correct horizontally ( in the right position), and all point labels are in meters.  SO the problem is my point labels (all of my styles)  are showing elevations of 29-35  and my point list elevations are from 109-115.  Whats going on here?
HELP!
Please.
-David
Re: Point Elevations Labels displaying incorrectly.
« Reply #1 on: November 27, 2014, 03:51:47 PM »
Can you post the drawing and text files?
« Reply #2 on: November 27, 2014, 05:39:09 PM »
The Drawing's settings are set to feet, change it to Meters and all is well:
DPATTERSON
« Reply #3 on: November 28, 2014, 08:18:53 AM »
Awesome Thank you!!!
« Reply #4 on: December 01, 2014, 08:46:02 AM »
You should consider using the Metric template if you want to work in Meters by default.
DPATTERSON
« Reply #5 on: December 10, 2014, 03:29:32 PM »
mjfarrell,
I export from topcon 3d-office and it defaults to imperial.
« Reply #6 on: December 10, 2014, 03:40:44 PM »
mjfarrell,
Perhaps copy/place the Metric template in place of that Imperial one.
caddcop
« Reply #7 on: December 12, 2014, 03:17:16 PM »
Be careful switching units on a file with data. A label style might be defined to label elevations in a particular unit. We ended up with either contour labels or some other point label that was listing elevations in the wrong units.
