Author Topic: Dimension Style Updater  (Read 1405 times)
Dave M
« on: June 06, 2013, 01:06:36 PM »
Is there a way to make a dimension style from one drawing match a dimension style from another of the same name?  Sort of like resetting to match a template
Any insight would be appreciated
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
Crank
Re: Dimension Style Updater
« Reply #1 on: June 06, 2013, 02:16:12 PM »
From the Express Tools, you can use the commands -.DIMEX and -.DIMIM.
Dave M
« Reply #2 on: June 06, 2013, 02:39:29 PM »
I used to use that tool, but now when I try to use it, the imported dimension styles have names that are numbers
Here's an example
Crank
« Reply #3 on: June 06, 2013, 04:28:17 PM »
I haven't used this tool in years , but the numbers have been there as long as I can remember.
You can open the .DIM file you just created using NotePad.
In the first line and last line is the autogenerated name, change it to the desired dimstyle name.
irneb
« Reply #4 on: June 07, 2013, 08:01:19 AM »
The numbers are for the dimension styles related to only specific types of dims. E.g. 7 is for leaders. Unfortunately those express tools was never updated when adesk added the sub-category styles.
I haven't make such lisp (or other) yet, but what I've done is to rename the main style in a DWG where the style is incorrect, then copy-paste a dim from a DWG where it is correct and match properties (use something like filter or quick select to select dimensions easier).
