Author Topic: Inserting Block, but reading from Excel  (Read 10657 times)
Re: Inserting Block, but reading from Excel
« Reply #15 on: January 18, 2010, 01:33:23 PM »
You might try this. {Untested}
(defun c:blkins (/ AllData data *error*)
ATTDIA
Controls whether the -INSERT command uses a dialog box for attribute value entry. See "INSERT Command Line."
0        Issues prompts on the command line
1        Uses a dialog box
ATTMODE
Controls display of attributes.
0        Off: Makes all attributes invisible
1        Normal: Retains current visibility of each attribute: visible attributes are
                displayed; invisible attributes are not
2        On: Makes all attributes visible
ATTREQ
Determines whether the INSERT command uses default attribute settings during insertion of blocks.
0        Assumes the defaults for the values of all attributes
1        Turns on prompts or dialog box for attribute values, as specified by ATTDIA
TEXTEVAL
Controls the method of evaluation of text strings.
0        All responses to prompts for text strings and attribute values are taken literally
1        Text starting with an opening parenthesis [ ( ] or an exclamation mark (!) is
            evaluated as an AutoLISP expression, as for nontextual input
  ;; error function & Routine Exit
  (defun *error* (msg)
      (not
        (member
          msg
          '("console break" "Function cancelled" "quit / exit abort" "")
    )               ; endif
    (and sysattdia (setvar "ATTDIA" sysattdia)) ; reset vars
    (and sysattreq (setvar "ATTREQ" sysattreq))
    (and systxteva (setvar "TEXTEVAL" systxteva))
    (setq sysattdia nil)
    (setq sysattreq nil)
    (setq systxteva nil)
  ;;  Start Here  -----------------
  (setq sysattdia (getvar "ATTDIA"))
  (setq sysattreq (getvar "ATTREQ"))
  (setq systxteva (getvar "TEXTEVAL"))
  (setvar "ATTDIA" 0)
  (setvar "ATTREQ" 1)
  (setvar "TEXTEVAL" 0)
  '(("R1"  "X coordinate" "Y coordinate" "Z coordinate"  "Rotation"
     "X Scale"  "Y Scale"  "Z Scale"  "Layer"  "Attribute 1" "Attribute 2")
    ("R2" "6" "12" "0" "0" "1" "1" "1" "2" "AB" "100")
    ("R3" "12" "6" "0" "90" "2" "2" "2" "3" "GE" "200"))
  (setq BlkName "MyBlockName")
  (setq Alldata
         (GetExcel "C:\\Documents and Settings\\dguenthner\\My Documents\\Attribute Info.xlsx" nil nil))
  (print data)
  (foreach data AllData
    (command "-INSERT" BlkName
     "X" (nth 5 data) "Y" (nth 6 data) "Z" (nth 7 data)
     "_none"  (list (nth 1 data)(nth 2 data)(nth 3 data))
     (nth 4 data)  ; Rotation angle (optional; default = 0)
     (nth 9 data)
     (nth 10 data)
    (command "_.chprop" (entlast) "" "LA" (nth 8 data) "")
  (CloseExcel nil)
HofCAD
« Reply #16 on: January 19, 2010, 12:30:10 PM »
hofCAD,
Thanks for your suggestion.  Unfortunately, I couldn't get the attribute values entered into the block's attribute.  After reviewing AutoCAD's commandline, I noticed the attribute values were being called, but AutoCAD couldn't locate a command.  So after the rotation values was supplied the insert command ended and the attribute value was entered at the command prompt.  Do I have to adjust something in AutoCAD to get the insert command to recognize the following attributes?
BTW I had a difficult time reading the comments.  What language was the vba written in?
Thanks, Debbie
Debbie,
Did you use the drawing HappyTot.dwg with the block Happy
with 2 attribute definitions?
Is at your local settings the decimal point separator a dot?
The macros in HappyBlok.xls are not really written in VBA,
but in Excel Dynamic Data Exchange (DDE) Macro language.
http://www.exceldde.com/
Some comment is made in Dutch.
Regards HofCAD CSI.
PS For 'Drawing a Helix Spiral in AutoCAD LT' or AutoCAD
with the Dynamic Data Exchange (DDE) method see:
http://forums.augi.com/showthread.php?t=112935
or http://www.theswamp.org/index.php?topic=31206.msg368008#msg368008
For 'Need lisp routine input a data in CAD' see:
http://forums.augi.com/showthread.php?t=98100&highlight=DDE-LINES.xls+hofcad
« Last Edit: January 19, 2010, 02:42:44 PM by HofCAD »
debgun
« Reply #17 on: January 19, 2010, 10:18:08 PM »
CAB & HofCAD,
I really appreciate your help.  I got your codes to work.
