>>just did it on my wild guess...
Got it now.
>>if i had a chance will do some quick test in objectarx, but no promises.
Thanks.
>>did you closed the palette?
Yes and no problem. The issue is when clicking on a layer name in the palette immediately after running the lisp routine.
>>and ran any test and still you are getting the same message?
Still same issue without any of my code loaded and running this to test:
(defun c:test (/ point) (setq point (getpoint)))
>>- also will be good idea if you post some code
>>also, any luck about finding info about the error on the net?
Nope.
