Author Topic: Unable to modify layers while a command is active  (Read 10379 times)
Spike Wilbury
Re: Unable to modify layers while a command is active
« Reply #15 on: September 02, 2009, 02:19:35 PM »
The problem is not the reactors is the layer palette :)
Ron,
Have you checked for any running reactors?
Like maybe worth just shooting a vlr-pers-list at the command line...
« Reply #16 on: September 02, 2009, 02:25:41 PM »
Ron,
(vlr-pers-list) = NIL
Thanks for the suggestion Lee.
« Reply #17 on: September 02, 2009, 02:26:53 PM »
Ron,
Can you explain this Luis?
Spike Wilbury
« Reply #18 on: September 02, 2009, 02:38:20 PM »
just did it on my wild guess... if i had a chance will do some quick test in objectarx, but no promises.
did you closed the palette? and ran any test and still you are getting the same message? - also will be good idea if you post some code
also, any luck about finding info about the error on the net?
LE!
« Reply #19 on: September 02, 2009, 03:13:55 PM »
Got it now.
Thanks.
Yes and no problem. The issue is when clicking on a layer name in the palette immediately after running the lisp routine.
Still same issue without any of my code loaded and running this to test:
(defun c:test (/ point) (setq point (getpoint))) >>- also will be good idea if you post some code
Nope. :-(
KewlToyZ
« Reply #20 on: September 02, 2009, 03:37:26 PM »
Ahhh now I see, you run a routine with the Layer Palette on Autohide, the routine stays open unable to finish?
Perhaps closing and reopening the layer palette during the routine would help?
The layer palette is handy but really seems to eat serious resources with multiple files open or during layer commands being issued for my workstations. It may just not be able to post the data properly while it is cahced for the search filters in its running state?
Spike Wilbury
« Reply #21 on: September 02, 2009, 06:59:15 PM »
ron,
i just got the chance to run a test here on a2009 - and yes it is the palette - or a bug - or the way they designed
« Last Edit: September 03, 2009, 11:23:08 AM by Esquivel »
Spike Wilbury
« Reply #22 on: September 02, 2009, 07:40:46 PM »
two workarounds i found
1. have the palette on auto-hide
2. afert calling the lisp, make an implied selection - that looks like kills any active command
hth
