Author Topic: Add text strings that have ft. & inches  (Read 3105 times)
BillB
« on: June 07, 2005, 01:06:57 PM »
O.k.,,I have looked and searched and looked some more,,but I can not find a lisp that would do the following. I have several (alot) of sheets that have text called out in lineal feet of material in feet-inches, would like to be able to add these all up (text) and come up with a total sum. Have come up with a couple of lisps but they can't handle the inch or fractions of an inch. was wondering if this could be done.
I alway appreciate your help,,,many thanks
BillB
whdjr
« Reply #1 on: June 07, 2005, 01:28:46 PM »
How is your text displayed?
Is it text? mtext? attribute?
Can you give a screen shot?
BillB
« Reply #2 on: June 07, 2005, 01:36:55 PM »
Ahhh,,,sorry,,duh,,,will be dtext and it looks like for example  18'-4",,,no spaces. oh, I run Acad 2002 w/XP Pro
« Reply #3 on: June 07, 2005, 01:51:39 PM »
(defun c:addvals ( / index repval ss2add total)
  (setq ss2add (ssget)
        index  0
        repval (sslength ss2add)
total 0
  (repeat repval
    (setq total (+ total (distof (cdr (assoc 1 (entget (ssname ss2add index)))))))
    (setq index (1+ index))
  (alert (strcat "Total is: " (rtos total)))
BillB
« Reply #4 on: June 07, 2005, 02:25:17 PM »
Hey,,,thanks Keith,,,works good except if I pick around 15 text strings I get this
"; error: bad argument type: numberp: nil "
Not sure why
BillB
« Reply #5 on: June 07, 2005, 02:46:19 PM »
Chances are you have selected a bit of text that is either not entirely an architectural length, is mtext, or has some other formatting code such as underlining etc.
« Reply #6 on: June 07, 2005, 03:42:08 PM »
Yea, just add some error checking & it will overlook most items.
(defun c:addvals (/ ss ename total num msg)
  (setq ss    (ssget '((0 . "TEXT")))
        i     -1
        total 0
  (if ss
       (while (setq ename (ssname ss (setq i (1+ i))))
         (if (setq num (distof (cdr (assoc 1 (entget ename)))))
           (setq total (+ total num))
    ((null ss)
     (setq msg "    Nothing Selected"))
    ((zerop total)
     (setq msg "      Zero Total"))
    (t
     (setq msg (strcat "   Total is: " (rtos total))))
  (alert msg)
« Reply #7 on: June 07, 2005, 03:56:37 PM »
Nice addition CAB ... this program was actually part of a larger routine that I wrote many years ago. In the larger program I had error checking and the data being passed was known. The addition of error checking here will solve most of the problems.
« Reply #8 on: June 07, 2005, 04:18:43 PM »
Thanks Keith, I fingered as much.
BillB
« Reply #9 on: June 08, 2005, 01:57:54 PM »
Hey guys,,,thanks,,seems to work great
except when you have more then one
string that have the same values,,,it
won't count it,,any ideas?
BillB
BillB
« Reply #10 on: June 08, 2005, 02:01:31 PM »
Oops,,,sorry guys,,,my fault,,,does work,,was a problem with my text,,,had on at 85'-0" and one at 85'-0',,note the dual feet on last one,,,again sorry,,,great job, will come in real handy.
Thanks again
BillB
ELOQUINTET
« Reply #11 on: June 08, 2005, 03:00:09 PM »
anyway to get this to work with dimension text by any chance  :?
« Reply #12 on: June 08, 2005, 03:06:21 PM »
Dan I think there is one arouund here somewhere ... I'll see what I can find..
