Author Topic: Viewports Display Off  (Read 3152 times)
DanB
« on: March 15, 2007, 12:40:15 PM »
Is it possible to have ALL Layout Viewports in a drawing turned off without going through each layout tab?
Re: Viewports Display Off
« Reply #1 on: March 15, 2007, 12:43:10 PM »
DanB
« Reply #2 on: March 15, 2007, 12:56:16 PM »
Thanks for the fast reply, it also lead me to the answer to my follow up question on locking them as well.
« Reply #3 on: March 15, 2007, 01:07:01 PM »
Here is a version of lock\unlock viewports:
;;UNLOCK OR LOCK ALL VPORTS
(defun c:vplockall (/ X lck prmpt ent clr clr2 obj)
  (initget 0 "Lock Unlock")
  (if (not *default*)
    (setq *default* "Lock")
  (setq
    X (cond
((getkword
   (strcat
     "\n (L)ock or (U)nlock all viewports?  <<Hit Enter for "
     *default*
(*default*)
  (setq *default* X)
  (cond ((= X "Lock")
(setq lck   :vlax-true
       prmpt "locked..."
       clr   5
       clr2  acBlue
((= X "Unlock")
(setq lck   :vlax-false
       prmpt "unlocked..."
       clr   1
       clr2  acRed
  (vlax-for lay (vla-get-layouts
  (vla-get-activedocument
    (vlax-get-acad-object)
    (if (eq :vlax-false (vla-get-modeltype lay))
      (vlax-for ent (vla-get-block lay)
(if (= (vla-get-objectname ent) "AcDbViewport")
    (vla-put-displaylocked ent lck)
    (vla-put-color ent clr)
    (if (setq
  obj (assoc 340 (entget (vlax-vla-object->ename ent)))
      (vla-put-color (vlax-ename->vla-object (cdr obj)) clr2)
  (princ (strcat "\n All viewports have been " prmpt))
« Reply #4 on: March 15, 2007, 02:35:04 PM »
« Reply #5 on: March 15, 2007, 02:40:05 PM »
You might want to read this.  It has some good information on viewports, and selecting all of them without stepping through each layout.
