Author Topic: Eliminate the Paper Space Viewport from a list of all viewports on a layout  (Read 17393 times)
Sdoman
I am trying to construct a list containing a sublist for each paperspace layout in the drawing.  The Car of a sublist will be the layout name (string). The Cdr of a sublist will be another list containing all paperspace vport objects references for that particular layout.
Here is an example of a list I am trying to construct:
(("Layout1"
     (#<VLA-OBJECT IAcadPViewport 064a9324>
      #<VLA-OBJECT IAcadPViewport 064a8c54>
    ("Layout2"
      (#<VLA-OBJECT IAcadPViewport 064a88a4>
       #<VLA-OBJECT IAcadPViewport 064a84f4>
       #<VLA-OBJECT IAcadPViewport 064adc54>
My problem is I don't want to include the paperspace viewport.  I thought I could eliminate the paperspace viewport by using ssget with a dxf filter.  However I am getting mixed results, sometimes it works, othertimes it doesn't.  So I am not sure if this is a correct way to accomplish this task.
Here's the code I have so far.  The first function is what I am working on.  The other two are supporting functions:
(defun sd:VpList (/ ss rslt)
  ;; Returns a list of layout names and vports objects
  ;; Requires subfunction LayoutList< and ss->objlst
  (foreach layout (sd:LayoutList<)
    (if (setq ss (ssget "x"
                        (list '(0 . "VIEWPORT")
                              (cons 410 layout)
                              '(-4 . ">")
                              '(68 . 0)  ;_ viewport status
      (setq rslt (cons (list layout (sd:ss->objlst ss)) rslt))
  (reverse rslt)
(defun sd:LayoutList< (/ layout name index)
  ;; sdoman
  ;; Returns list of layout names sorted by taborder
  ;; Excludes the "Model" layoutname
  (vlax-for layout (vla-get-layouts
    (setq name  (cons (vla-get-name layout) name)
          index (cons (vla-get-taborder layout) index)
  (cdr (mapcar '(lambda (x) (nth x name)) (vl-sort-i index '<)))
(defun sd:ss->objlst (ss / n lst)
  ;; Returns a list of vla-objects given a selection set
  (cond ((= (type ss) 'PICKSET)
         (setq n 0)
         (repeat (sslength ss)
           (setq lst (cons (vlax-ename->vla-object (ssname ss n)) lst)
                 n   (1+ n)
         (reverse lst)
Thanks,
Steve
How about if you check for dxf code 69.  I think that if it's 1 then it is the paper space viewport.
                              (cons 410 layout)
                              '(-4 . ">")
                              '(69 . 0)  ;_ viewport number
  (reverse rslt)
Sdoman
                              (cons 410 layout)
                              '(-4 . ">")
  (reverse rslt)
Thanks but that doesn't to work for me.  Wait let me check something...
Ok if I change the filter to: '(-4 . ">") '(69 . 1), it *seems* to work.  Going to do some testing...
fixd typo: dxf 69 -> 1
« Last Edit: July 11, 2006, 05:28:49 PM by 'steved »
You are right Steve.  I meant to put '(69 . 1).  It worked on a quick little test I did here.
Edit: Modified to test for valid selection set, lest it bomb.
Not sure I follow but this quick & dirty --
(defun foo ( / ss result key exist )
        (setq ss
            (ssget "x"
                    (0 . "VIEWPORT")
                    (-4 . "!=")
                    (69 . 1)
                    (-4 . ">")
                    (68 . 0)
        (vl-sort
            (foreach ename (mapcar 'cadr (ssnamex ss))
                (setq result
                        (setq exist
                            (assoc
                                (setq key (cdr (assoc 410 (entget ename))))
                                result
                        (subst
                            (list key
                                (cons
                                    (vlax-ename->vla-object ename)
                                    (cadr exist)
                            exist
                            result
                        (cons
                            (list key (list (vlax-ename->vla-object ename)))
                            result
           '(lambda (a b) (< (car a) (car b)))
Spews this --
    (   "Layout1"
        (   #<VLA-OBJECT IAcadPViewport 02c1e9f4>
            #<VLA-OBJECT IAcadPViewport 02c36734>
    (   "Layout2"
            #<VLA-OBJECT IAcadPViewport 02c1e8c4>
            #<VLA-OBJECT IAcadPViewport 02c2b904>
            #<VLA-OBJECT IAcadPViewport 02c365b4>
Use [abuse|discard|ignore] as you see fit.
« Last Edit: July 11, 2006, 06:20:32 PM by MP »
Nice code Michael.  I see more and more post with people using "ssnamex".  Guess it's time to learn a new trick.
Thanks Tim, please see the edit.
PS: A nod to our friend Evgeniy who illuminated the use of ssnamex.
Sdoman
Nice one MP.  Your code works well! And the ssget filter you used is interesting.
And what Tim said.  The ssnamex function is something I rarely have used.  That's so cool how you used it to get a list of enames.
Thanks Steve, just havin' some good ol' lispin' fun. Glad if it helps even if just a little.
Sdoman
MP,
It does help and thank you very much for posting.  I must admit to being a bit overwhelmed at first while trying to understand your algorithm.  But now that I've had a chance to study it, I find the code within the foreach loop really interesting.
Could you please comment on your ssget filter?  The help files totally confused me on which dxf code to use.  I think what your are filtering is: select all viewports which are on and not "Thee Paper Space" viewport. Right?
Hi Steve. As I understand it ssget filtering, without -4 groups to specify otherwise, employs implied and all the way.
So the filter as written says --
Select all entities that are viewports AND have an ID that is not equal to 1 (paperspace) AND have a status that is greater than 0 (on and active).
That is what I thought you wanted; hope I didn't veer too far of the desired track.
Happiness thru drugs; oh bliss.
PS: My pleasure Steve.
Sdoman
MP,
Coolness.  That is exactly what I want. Thanks.
Have a nice bliss : )
Thanks Steve, that makes me happer than a dung beetle at an elephant parade, or something like that.
 :lol:
Sdoman
Shoot!  Still having problems:
I came to work this morning, fired up AutoCAD, opened my test drawing that contains several paperspace layouts, Then I loaded and the 'foo function.  It returned a list containing the data for the current layout, but not the others.  I suspect the ssget filter is the problem.  Perhaps when a drawing is first opened, the viewports are not activated until the layout the viewport is located on is made active.
Any ideas?  Attached is drawing file I am using for testing (saved as a2k file format).
I can't D/L from here (mumble ...). Try this --
(ssget "x"
        (0 . "VIEWPORT")
        (-4 . "!=")
        (69 . 1)
        (-4 . "!=")
        (68 . 0)
It limits the selection to viewports that are not off, which means viewports that are on but not active (or visible, like off screen, maxactvp exceeded yada) can be selected. HTH.
/Shrug.
