Without more information, I think you have a serious problem and it's time for drastic measures.
Try to run a repair on AutoCAD.
If that does not work, a reinstall may be in order. Make sure to follow the direction from Autodesk for the reinstall if you have to do that. There is a procedure for fully uninstalling AutoCAD that is necessary for a reinstall to be clean.
