Author Topic: Creating new layer with plot styles  (Read 11162 times)
Re: Creating new layer with plot styles
« Reply #15 on: February 28, 2008, 07:42:26 AM »
Try this  :-o
//Hi Kerry :)
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcWd = Autodesk.AutoCAD.Windows;
#endregion
[assembly: CommandClass(typeof(ExecMethod.Commands))]
namespace ExecMethod
  public class Commands
    public ObjectId CreateLayer(string layerName, short layerColor, LineWeight lineweightName)
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      ObjectId layerId = ObjectId.Null;
        LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForWrite);
        if (lt.Has(layerName))
          layerId = lt[layerName];
          if (layerId.IsErased)
            LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(layerId, OpenMode.ForWrite, true);
            ltr.Erase(false);
            layerId = ltr.Id;
        else
          if (layerColor > 255)
            ed.WriteMessage(string.Format(" ERROR: Could not use LayerColor \"{0}\", using 0 instead.", layerColor));
            layerColor = 0;
          LayerTableRecord ltr = new LayerTableRecord();
          ltr.Name = layerName;
          ltr.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, layerColor);
          ltr.LineWeight = lineweightName;
          layerId = lt.Add(ltr);
          tr.AddNewlyCreatedDBObject(ltr, true);
        tr.Commit();
      return layerId;
    public void AddPlotStyle(string PlotStyleName)
      Database db = AcAp.Application.DocumentManager.MdiActiveDocument.Database;
      if (db.PlotStyleMode == false)
          using (PlaceHolder hldr = new PlaceHolder())
            DictionaryWithDefaultDictionary d =
              (DictionaryWithDefaultDictionary)tr.GetObject
                  (db.PlotStyleNameDictionaryId, OpenMode.ForWrite);
            d.SetAt(PlotStyleName, hldr);
            tr.Commit();
    public void AddPlotStyleToLayer(ObjectId id, string PlotStyleName)
                (db.PlotStyleNameDictionaryId, OpenMode.ForRead);
               (LayerTableRecord)tr.GetObject(id, OpenMode.ForWrite);
          ltr.PlotStyleNameId = d.GetAt(PlotStyleName);
          tr.Commit();
    [CommandMethod("doit")]
    public void doit()
      try
        string plotstyle = "Style 1";
        AddPlotStyle(plotstyle);
        ObjectId id = this.CreateLayer("Daniel", 7, LineWeight.ByLayer);
        AddPlotStyleToLayer(id, plotstyle);
      catch (System.Exception ex)
        ed.WriteMessage("\n" + ex.Message + "\n" + ex.StackTrace);
« Last Edit: February 28, 2008, 08:53:51 AM by Daniel »
« Reply #16 on: February 28, 2008, 07:44:59 AM »
mcarson
« Reply #17 on: February 28, 2008, 10:11:12 AM »
Excellent! :-D
What you have provided works in itself. I now have to build it into my program.
Thanks very much!
Bryco
« Reply #18 on: February 28, 2008, 10:21:31 AM »
PlaceHolder hldr, that's a pretty cool find Daniel, this C# stuff doesn't seem to get any easier. I used to think the vba help files were bad but compared to C# they are amazing.
« Reply #19 on: February 28, 2008, 02:53:29 PM »
well researched Daniel !
« Reply #20 on: February 28, 2008, 10:32:37 PM »
Excellent! :-D
Thanks very much!
You’re welcome, I must admit I probably would never had got this one if it wasn’t for Art Cooney’s post.
mcarson
« Reply #21 on: February 29, 2008, 05:25:49 AM »
Another can of worms...
Attempt to add the layer more than once, and have a look at the ACAD layer dialog each time
The plot style name does not stay assigned to the layer, instead it moves with each new layer.
Am I getting this all wrong?
« Reply #22 on: February 29, 2008, 05:55:54 AM »
you might try testing if the style exists ie
            if (!d.Contains(PlotStyleName))//added
            tr.Commit();
« Last Edit: February 29, 2008, 07:45:40 AM by Daniel »
mcarson
« Reply #23 on: February 29, 2008, 05:59:01 AM »
I just done that while waiting on a reply; you're faster than I am!
Works now!
Thanks again!
I'll post my full code over the weekend
« Reply #24 on: February 29, 2008, 07:49:44 AM »
Good deal!, usually the code I post is rough draft,  :-o
you should probably add your error checking, try catches etc.,
and maybe even pass the working database as a parameter.
« Reply #25 on: February 29, 2008, 06:00:37 PM »
Quote from: Dan
Latitude 22°17'33.02"N  Longitude 113°57'1.73"E
Dan, what's your Vertitude ?
« Reply #26 on: February 29, 2008, 06:09:24 PM »
Kinda personal dontcha think?
 :lol:
« Reply #27 on: March 02, 2008, 06:43:49 AM »
Quote from: Dan
33rd floor, maybe 100 or so meters MSL
PS. If you visit, bring black licorice  :laugh:
« Last Edit: March 02, 2008, 07:02:14 AM by Daniel »
stevenh0616
« Reply #28 on: October 18, 2012, 02:52:39 PM »
Thanks everyone for this great set of posts... this all worked really well as I encountered the same issues.
I think I saw someone ask about checking if the drawing uses CTBs or STBs. Here is some code to do just that, and it works well. Basically it just checks the system variable PSTYLEMODE and returns a boolean value, so if it's style mode, then you can apply the plot style to the layers.
Code - vb.net: [Select]
  1. Public Shared Function GetPlotStyleModeTrueColorFalseStyle() As Boolean
  2.         Dim result As Boolean = False
  3.         If Convert.ToInt32(Application.GetSystemVariable("pstylemode")) = 1 Then
  4.             result = True
  5.         End If
  6.         Return result
  7.     End Function
