Author Topic: Edit block attribute when block is already a part of DWG  (Read 1878 times)
Pilatus4me
« on: August 26, 2014, 05:39:36 PM »
The basics: Autocad 2014 VB.net
I have no issues opening the autocad file or doing a save as but I am very new to autocad and even newer as far as getting vb.net to work with it. For the last 2 days I have been searching both here and all over the internet and either what I am seeing doesn't make sense to me or when I try it there are numerous bugs in the sample code.
What I want to do: Open an autocad file, insert data into various block attributes (file has several blocks), then save the file with a different name. Repeat until all of the records in the database are done.
There has to be a relatively simple way to do this but I am too blurry eyed to figure it out. Any suggestions would be greatly appreciated. Even pointing me to resources that are accurate would be great.
Jeff H
Re: Edit block attribute when block is already a part of DWG
« Reply #1 on: August 26, 2014, 06:12:34 PM »
Break it down
Open a drawing with or without editor?
Would seem that you typical insert "data"(which would be a string) for attribute references but might do it for definitions, I have no idea so I guess these drawings each contain a few BlockReferences that your trying to assign the value for its attributeReferences?
Is that something we need to worry about? If it is or could be replaced with a collection file names then no.
Pilatus4me
« Reply #2 on: August 26, 2014, 06:32:40 PM »
With the editor is fine. This will only run on my machine and will not be distributed.
as far as the repeating is concerned right now I would be happy with being able to just insert some data into the drawing. I can handle the repeating part.
There are several blocks in the graphic, each with multiple tags that I want to change the values on, see attachment.
