Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Delete arcs from pline - lisp request
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Delete arcs from pline - lisp request (Read 4778 times)
ribarm
Gator
Marko Ribar, architect
WWW
Re: Delete arcs from pline - lisp request
Reply #15 on:
December 10, 2023, 04:32:55 PM »
Here you are... Just make sure start and end segments are straight... And you have to have at least single straight between arced segments...
Code - Auto/Visual Lisp:
[Select]
;; Decurve - Lee Mac
;; Equivalent to applying a zero-radius fillet to a polyline with arc-segments
defun
c:decurve
ptonline lwv
ptb LM:BulgeRadius unique k enx hed idx int lst ocs rtn sel
defun
ptonline
pt1 pt2 pt3
equal
distance
pt1 pt3
distance
pt1 pt2
distance
pt2 pt3
1e
8
defun
lwv
ptb
lst
if
setq
lst
member
assoc
10
lst
lst
cons
list
assoc
10
lst
assoc
42
lst
lwv
ptb
cdr
lst
;; Bulge Radius - Lee Mac
;; p1 - start vertex
;; p2 - end vertex
;; b - bulge
;; Returns the radius of the arc described by the given bulge and vertices
defun
LM:BulgeRadius
p1 p2 b
distance
p1 p2
1+
b b
4
abs
b
defun
unique
lst
a ll
while
setq
a
car
lst
if
vl-some
function
lambda
x
equal
x a 1e
6
cdr
lst
setq
ll
cons
a ll
lst
vl
remove
if
function
lambda
x
equal
x a 1e
6
cdr
lst
setq
ll
cons
a ll
lst
cdr
lst
reverse
ll
while
8
logand
8
getvar
'undoctl
vl-cmdf
"_.undo"
"_e"
vl-cmdf
"_.undo"
"_be"
if
and
setq
sel
ssget
"_:L"
0
"LWPOLYLINE"
4
"<NOT"
4
70
1
4
"NOT>"
not
initget
7
setq
rad
getdist
\n
Pick or specify top radius of curving to preserve curvature : "
repeat
setq
idx
sslength
sel
setq
enx
entget
ssname
sel
setq
idx
1-
idx
hed
reverse
member
assoc
38
enx
reverse
enx
ocs
cdr
assoc
210
enx
lst
nil
lst
lwv
ptb enx
rtn
nil
setq
k
1
foreach
x lst
setq
k
1+
k
cond
equal
0.0
cdr
assoc
42
x
1e
8
setq
rtn
cons
x rtn
t
if
LM:BulgeRadius
cdr
car
nth
k lst
cdr
car
nth
1+
k
lst
cdr
cadr
nth
k lst
rad
if
k
2
1-
length
lst
progn
setq
int
inters
cdr
car
nth
1-
k
lst
cdr
car
nth
k lst
cdr
car
nth
1+
k
lst
cdr
car
nth
2
k
lst
nil
setq
rtn
cons
list
cons
10
cdr
car
nth
k lst
cons
42
0.0
rtn
setq
rtn
cons
list
cons
10
int
cons
42
0.0
rtn
setq
rtn
cons
list
cons
10
cdr
car
nth
1+
k
lst
cons
42
0.0
rtn
setq
rtn
cons
x rtn
setq
rtn
unique rtn
if
entmake
append
subst
cons
90
length
rtn
assoc
90
hed
hed
apply
append
reverse
rtn
list
cons
210
ocs
entdel
cdr
assoc
1
enx
vl-cmdf
"_.undo"
"_e"
princ
HTH.
M.R.
Last Edit: December 11, 2023, 07:13:58 AM by ribarm
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
