Author Topic: Strange behavior with the insertion of a block.  (Read 1868 times)
Giuseppe Beatrice
« on: September 06, 2016, 06:22:21 AM »
I have a really strange problem.
If I want to insert a block definition without inserting the block in the drawing, I have to use the instruction:
(command <full name of the block> nil)
All goes perfectly, but if I use a slightly different type of instruction it's not so more:
- with (command-s <full name of the block> nil) I have an error ... (command-s) unknown
- with (vl-cmdf <full name of the block> nil) I have an error ... Application Error: Invalid type sent as input comand
Can anyone please explain why these strangeness happens?
Thanks in advance.
ChrisCarlson
Re: Strange behavior with the insertion of a block.
« Reply #1 on: September 06, 2016, 08:13:17 AM »
A block name is not a command name. Why not just use insert or a variant thereof?
« Reply #2 on: September 06, 2016, 08:26:25 AM »
Since vl-cmdf evaluates the validity of the arguments prior to submitting them to the command-line, this expression will error if supplied with invalid input.
Giuseppe Beatrice
« Reply #3 on: September 06, 2016, 09:17:28 AM »
I regret for the lack of clarity; of course the complete instruction was (command "_.-insert" <ful-name-block> nil).
Many thanks Lee, you have lighted up my ignorance; then, even command-s return an error for the same reason.
Is there another way but (command "_.-insert" <ful-name-block> nil) to insert a block without inserting an instance of it in the drawing?
« Last Edit: September 06, 2016, 09:20:36 AM by Giuseppe Beatrice »
ChrisCarlson
« Reply #4 on: September 06, 2016, 10:15:42 AM »
I would insert the block and delete the new instance
  1. (if
  2.         (vl-cmdf "._insert" blk "_S" 1.0 "_R" 0.0 "_non" "0,0,0")
  3.                 (vl-cmdf "_.erase" (ssget "L") "")
  4.                 (princ "Block Insertion Error")
  5. )
snownut2
  • Bricscad 22 Ultimate
« Reply #5 on: September 06, 2016, 12:31:00 PM »
There's always this.
http://www.lee-mac.com/copyblockdefinition.html
From Lee Mac....
« Reply #6 on: September 06, 2016, 12:51:32 PM »
This isn't quite the same thing but it's inevitable someone will want to copy a block def between docs (which can be ODBX docs) ...
(defun _CopyBlockDef ( sourcedoc blockname targetdoc / block )
    (and
        (null
            (vl-catch-all-error-p
                (setq block
                    (vl-catch-all-apply
                        (function
                            (lambda ( )
                                (vla-item
                                    (vla-get-blocks sourcedoc)
                                    blockname
        (null
                (vl-catch-all-apply
                   '(lambda ( )
                        (vlax-invoke-method
                            sourceDoc
                           'CopyObjects
                            (vlax-safearray-fill
                                (vlax-make-safearray
                                    vlax-vbObject
                                   '(0 . 0)
                                (list block)
                            (vla-get-blocks targetdoc)
FWIW cheers.
« Reply #7 on: September 06, 2016, 04:11:25 PM »
You may get some ideas from this old program: Import Block.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #8 on: September 06, 2016, 07:17:03 PM »
I'm bewildered.
Have you tried the built in ADCENTER ??
The DesignCenter was designed to replicate table data.
It doesn't handle UCS's, but I imagine there are several shared versions on the site.
added: here's one from 9 years ago https://www.theswamp.org/index.php?topic=16994.msg205851#msg205851
« Last Edit: September 06, 2016, 07:22:39 PM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
Giuseppe Beatrice
« Reply #9 on: September 07, 2016, 06:25:55 AM »
Your availability is huge and I can only thank you all.
I think theswamp is the best site to learn Lisp.  :yay!:
