I have a really strange problem.
If I want to insert a block definition without inserting the block in the drawing, I have to use the instruction:
(command <full name of the block> nil)
All goes perfectly, but if I use a slightly different type of instruction it's not so more:
- with (command-s <full name of the block> nil) I have an error ... (command-s) unknown
- with (vl-cmdf <full name of the block> nil) I have an error ... Application Error: Invalid type sent as input comand
Can anyone please explain why these strangeness happens?
Thanks in advance.
