Author Topic: Purging text styles  (Read 2040 times)
  • Custom Title
Purging text styles
« on: February 24, 2015, 08:26:38 AM »
I have 2 text styles in a dwg that i want to purge but it will not let me, it says "style still in use" and can not purge it. I have looked throughout the dwg but can not find the styles in use anywhere! Not even blocks. Anyone know how to find and get rid of these things?
thanks
Rob...
Re: Purging text styles
« Reply #1 on: February 24, 2015, 08:29:09 AM »
Can you post a file that you cannot purge them from?
Did you check dimension styles?
CAD Tech
ChrisCarlson
« Reply #2 on: February 24, 2015, 08:44:06 AM »
mleaderstyle, tablestyle, dimstyle are the usual culprits.
« Reply #3 on: February 24, 2015, 08:55:24 AM »
they might be in attribute definitions within a block
OR
IF
this is a C3D file they are set within a feature setting, or a command setting
  • Custom Title
« Reply #4 on: February 24, 2015, 08:58:32 AM »
It isn't in any; mleaderstyle, tablestyle, dimstyle.
huiz
  • Certified Prof C3D
« Reply #5 on: February 24, 2015, 09:00:50 AM »
With the tool MgdDbg you can snoop the Database to see which objects are linked to the Text style.
ChrisCarlson
« Reply #6 on: February 24, 2015, 09:02:42 AM »
Any complex linetypes?
  • Custom Title
« Reply #7 on: February 24, 2015, 09:04:59 AM »
I thought the same thing but it wasn't there.
FOUND IT!! The style was in a block. *sigh*
  • Custom Title
« Reply #8 on: February 24, 2015, 09:10:19 AM »
Cool. Will look into it.
dtkell
« Reply #9 on: February 24, 2015, 10:28:34 AM »
Glad you found it.
Another good place for them to hide is in empty text strings.
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
