I thought somebody else might find this useful, plus I thought it might elicit some comments I can learn from.
using System;
using System.IO;
using System.Text;
using Autodesk.AutoCAD.Windows;
using ofdFlags = Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags;
[assembly: ExtensionApplication(typeof(cgabriel.XrefTools))]
[assembly: CommandClass(typeof(cgabriel.XrefTools))]
namespace cgabriel
public class XrefTools : IExtensionApplication
#region ExtensionAppImplementation
public void Initialize() { }
public void Terminate() { }
#endregion
#region Helpers
public delegate void ProcessSingleXref(BlockTableRecord btr);
public delegate void ProcessMultipleXrefs(ObjectIdCollection xrefIds);
public static void detachXref(BlockTableRecord btr)
Application.DocumentManager.MdiActiveDocument.Database.DetachXref(btr.ObjectId);
public static void openXref(BlockTableRecord btr)
string xrefPath = btr.PathName;
if (xrefPath.Contains("..\\"))
string hostPath =
Application.DocumentManager.MdiActiveDocument.Database.Filename;
Directory.SetCurrentDirectory(Path.GetDirectoryName(hostPath));
xrefPath = Path.GetFullPath(xrefPath);
if (!File.Exists(xrefPath)) return;
Document doc = Application.DocumentManager.Open(xrefPath, false);
if (doc.IsReadOnly)
System.Windows.Forms.MessageBox.Show(
doc.Name + " opened in read-only mode.",
"OpenXrefs",
System.Windows.Forms.MessageBoxButtons.OK,
System.Windows.Forms.MessageBoxIcon.Warning);
public static void bindXrefs(ObjectIdCollection xrefIds)
Application.DocumentManager.MdiActiveDocument.Database.BindXrefs(xrefIds, false);
public static void reloadXrefs(ObjectIdCollection xrefIds)
Application.DocumentManager.MdiActiveDocument.Database.ReloadXrefs(xrefIds);
public static void unloadXrefs(ObjectIdCollection xrefIds)
Application.DocumentManager.MdiActiveDocument.Database.UnloadXrefs(xrefIds);
public static void processXrefs(string promptMessage, ProcessSingleXref process)
TypedValue[] filterList = { new TypedValue(0, "INSERT") };
ed.WriteMessage(promptMessage);
PromptSelectionResult result = ed.GetSelection(new SelectionFilter(filterList));
if (result.Status != PromptStatus.OK) return;
ObjectId[] ids = result.Value.GetObjectIds();
Database db = Application.DocumentManager.MdiActiveDocument.Database;
ObjectIdCollection xrefIds = new ObjectIdCollection();
foreach (ObjectId id in ids)
BlockReference blockRef = (BlockReference)tr.GetObject(id, OpenMode.ForRead, false, true);
ObjectId bId = blockRef.BlockTableRecord;
if (!xrefIds.Contains(bId))
xrefIds.Add(bId);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bId, OpenMode.ForRead);
if (btr.IsFromExternalReference)
process(btr);
tr.Commit();
public static void processXrefs(string promptMessage, ProcessMultipleXrefs process)
ObjectIdCollection blockIds = new ObjectIdCollection();
blockIds.Add(blockRef.BlockTableRecord);
ObjectIdCollection xrefIds = filterXrefIds(blockIds);
if (xrefIds.Count != 0)
process(xrefIds);
tr.Commit();
public static void attachXrefs(string[] fileNames)
Array.Sort(fileNames);
double dimscale = db.Dimscale;
foreach (string fileName in fileNames)
PromptPointOptions options = new PromptPointOptions("Pick insertion point for " + fileName + ": ");
options.AllowNone = false;
PromptPointResult pt = ed.GetPoint(options);
if (pt.Status != PromptStatus.OK) continue;
double xrefScale = getDwgScale(fileName);
double scaleFactor = dimscale / xrefScale;
using (Transaction tr = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction())
ObjectId xrefId = db.AttachXref(fileName, Path.GetFileNameWithoutExtension(fileName));
BlockReference blockRef = new BlockReference(pt.Value, xrefId);
BlockTableRecord layoutBlock = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
blockRef.ScaleFactors = new Scale3d(scaleFactor, scaleFactor, scaleFactor);
blockRef.Layer = "0";
layoutBlock.AppendEntity(blockRef);
tr.AddNewlyCreatedDBObject(blockRef, true);
tr.Commit();
public static double getDwgScale(string fileName)
using (Database db = new Database(false, true))
db.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, false, string.Empty);
return db.Dimscale;
public static ObjectIdCollection filterXrefIds(ObjectIdCollection blockIds)
foreach (ObjectId bId in blockIds)
BlockTableRecord btr = (BlockTableRecord)bId.GetObject(OpenMode.ForRead);
xrefIds.Add(bId);
return xrefIds;
#endregion
#region Commands
[CommandMethod("XrefTools", "AttachXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
public static void XrefAttach()
string initFolder = Application.DocumentManager.MdiActiveDocument.Database.Filename.ToUpper();
if (initFolder.Contains("PLOT"))
initFolder = initFolder.Replace("-PLOT.DWG", "");
initFolder = initFolder.Replace("PLOT\\", "");
if (!Directory.Exists(initFolder))
initFolder = Application.DocumentManager.MdiActiveDocument.Database.Filename;
ofdFlags flags = ofdFlags.DefaultIsFolder | ofdFlags.AllowMultiple;
OpenFileDialog dlg = new OpenFileDialog("Select Drawings to Attach", initFolder, "dwg", "Select Xrefs", flags);
if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
attachXrefs(dlg.GetFilenames());
[CommandMethod("XrefTools", "BindXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
public static void XrefBind()
processXrefs("\nSelect xrefs to bind: ", XrefTools.bindXrefs);
[CommandMethod("XrefTools", "DetachXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
public static void XrefDetach()
processXrefs("\nSelect xrefs to detach: ", XrefTools.detachXref);
[CommandMethod("XrefTools", "OpenXrefs", CommandFlags.Session)]
public static void XrefOpen()
processXrefs("\nSelect xrefs to open: ", XrefTools.openXref);
[CommandMethod("XrefTools", "ReloadXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
public static void XrefReload()
processXrefs("\nSelect xrefs to reload: ", XrefTools.reloadXrefs);
[CommandMethod("XrefTools", "ReloadAllXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
public static void XrefReloadAll()
BlockTable blockTbl = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
foreach (ObjectId bId in blockTbl)
blockIds.Add(bId);
db.ReloadXrefs(xrefIds);
tr.Commit();
[CommandMethod("XrefTools", "UnloadXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
public static void XrefUnload()
processXrefs("\nSelect xrefs to unload: ", XrefTools.unloadXrefs);
#endregion
