Author Topic: Xref Tools  (Read 11936 times)
Chuck Gabriel
Xref Tools
« on: July 09, 2008, 01:57:32 PM »
I thought somebody else might find this useful, plus I thought it might elicit some comments I can learn from.
using System;
using System.IO;
using System.Text;
using Autodesk.AutoCAD.Windows;
using ofdFlags = Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags;
[assembly: ExtensionApplication(typeof(cgabriel.XrefTools))]
[assembly: CommandClass(typeof(cgabriel.XrefTools))]
namespace cgabriel
    public class XrefTools : IExtensionApplication
        #region ExtensionAppImplementation
        public void Initialize() { }
        public void Terminate() { }
        #endregion
        #region Helpers
        public delegate void ProcessSingleXref(BlockTableRecord btr);
        public delegate void ProcessMultipleXrefs(ObjectIdCollection xrefIds);
        public static void detachXref(BlockTableRecord btr)
            Application.DocumentManager.MdiActiveDocument.Database.DetachXref(btr.ObjectId);
        public static void openXref(BlockTableRecord btr)
            string xrefPath = btr.PathName;
            if (xrefPath.Contains("..\\"))
                string hostPath =
                    Application.DocumentManager.MdiActiveDocument.Database.Filename;
                Directory.SetCurrentDirectory(Path.GetDirectoryName(hostPath));
                xrefPath = Path.GetFullPath(xrefPath);
            if (!File.Exists(xrefPath)) return;
            Document doc = Application.DocumentManager.Open(xrefPath, false);
            if (doc.IsReadOnly)
                System.Windows.Forms.MessageBox.Show(
                    doc.Name + " opened in read-only mode.",
                    "OpenXrefs",
                    System.Windows.Forms.MessageBoxButtons.OK,
                    System.Windows.Forms.MessageBoxIcon.Warning);
        public static void bindXrefs(ObjectIdCollection xrefIds)
            Application.DocumentManager.MdiActiveDocument.Database.BindXrefs(xrefIds, false);
        public static void reloadXrefs(ObjectIdCollection xrefIds)
            Application.DocumentManager.MdiActiveDocument.Database.ReloadXrefs(xrefIds);
        public static void unloadXrefs(ObjectIdCollection xrefIds)
            Application.DocumentManager.MdiActiveDocument.Database.UnloadXrefs(xrefIds);
        public static void processXrefs(string promptMessage, ProcessSingleXref process)
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            TypedValue[] filterList = { new TypedValue(0, "INSERT") };
            ed.WriteMessage(promptMessage);
            PromptSelectionResult result = ed.GetSelection(new SelectionFilter(filterList));
            if (result.Status != PromptStatus.OK) return;
            ObjectId[] ids = result.Value.GetObjectIds();
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
                ObjectIdCollection xrefIds = new ObjectIdCollection();
                foreach (ObjectId id in ids)
                    BlockReference blockRef = (BlockReference)tr.GetObject(id, OpenMode.ForRead, false, true);
                    ObjectId bId = blockRef.BlockTableRecord;
                    if (!xrefIds.Contains(bId))
                        xrefIds.Add(bId);
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bId, OpenMode.ForRead);
                        if (btr.IsFromExternalReference)
                            process(btr);
                tr.Commit();
        public static void processXrefs(string promptMessage, ProcessMultipleXrefs process)
                ObjectIdCollection blockIds = new ObjectIdCollection();
                    blockIds.Add(blockRef.BlockTableRecord);
                ObjectIdCollection xrefIds = filterXrefIds(blockIds);
                if (xrefIds.Count != 0)
                    process(xrefIds);
                tr.Commit();
        public static void attachXrefs(string[] fileNames)
            Array.Sort(fileNames);
            double dimscale = db.Dimscale;
            foreach (string fileName in fileNames)
                PromptPointOptions options = new PromptPointOptions("Pick insertion point for " + fileName + ": ");
                options.AllowNone = false;
                PromptPointResult pt = ed.GetPoint(options);
                if (pt.Status != PromptStatus.OK) continue;
                double xrefScale = getDwgScale(fileName);
                double scaleFactor = dimscale / xrefScale;
                using (Transaction tr = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction())
                    ObjectId xrefId = db.AttachXref(fileName, Path.GetFileNameWithoutExtension(fileName));
                    BlockReference blockRef = new BlockReference(pt.Value, xrefId);
                    BlockTableRecord layoutBlock = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    blockRef.ScaleFactors = new Scale3d(scaleFactor, scaleFactor, scaleFactor);
                    blockRef.Layer = "0";
                    layoutBlock.AppendEntity(blockRef);
                    tr.AddNewlyCreatedDBObject(blockRef, true);
                    tr.Commit();
        public static double getDwgScale(string fileName)
            using (Database db = new Database(false, true))
                db.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, false, string.Empty);
                return db.Dimscale;
        public static ObjectIdCollection filterXrefIds(ObjectIdCollection blockIds)
            foreach (ObjectId bId in blockIds)
                    BlockTableRecord btr = (BlockTableRecord)bId.GetObject(OpenMode.ForRead);
                        xrefIds.Add(bId);
            return xrefIds;
        #endregion
        #region Commands
        [CommandMethod("XrefTools", "AttachXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
        public static void XrefAttach()
            string initFolder = Application.DocumentManager.MdiActiveDocument.Database.Filename.ToUpper();
            if (initFolder.Contains("PLOT"))
                initFolder = initFolder.Replace("-PLOT.DWG", "");
                initFolder = initFolder.Replace("PLOT\\", "");
                if (!Directory.Exists(initFolder))
                    initFolder = Application.DocumentManager.MdiActiveDocument.Database.Filename;
            ofdFlags flags = ofdFlags.DefaultIsFolder | ofdFlags.AllowMultiple;
            OpenFileDialog dlg = new OpenFileDialog("Select Drawings to Attach", initFolder, "dwg", "Select Xrefs", flags);
            if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
                attachXrefs(dlg.GetFilenames());
        [CommandMethod("XrefTools", "BindXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
        public static void XrefBind()
            processXrefs("\nSelect xrefs to bind: ", XrefTools.bindXrefs);
        [CommandMethod("XrefTools", "DetachXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
        public static void XrefDetach()
            processXrefs("\nSelect xrefs to detach: ", XrefTools.detachXref);
        [CommandMethod("XrefTools", "OpenXrefs", CommandFlags.Session)]
        public static void XrefOpen()
            processXrefs("\nSelect xrefs to open: ", XrefTools.openXref);
        [CommandMethod("XrefTools", "ReloadXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
        public static void XrefReload()
            processXrefs("\nSelect xrefs to reload: ", XrefTools.reloadXrefs);
        [CommandMethod("XrefTools", "ReloadAllXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
        public static void XrefReloadAll()
                BlockTable blockTbl = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                foreach (ObjectId bId in blockTbl)
                    blockIds.Add(bId);
                    db.ReloadXrefs(xrefIds);
                tr.Commit();
        [CommandMethod("XrefTools", "UnloadXrefs", CommandFlags.Modal | CommandFlags.DocExclusiveLock)]
        public static void XrefUnload()
            processXrefs("\nSelect xrefs to unload: ", XrefTools.unloadXrefs);
        #endregion
FengK
Re: Xref Tools
« Reply #1 on: July 09, 2008, 02:50:48 PM »
Thanks Chuck. I got an error when trying to compile it:
The name 'FileOpenMode' does not exist in the current context (CS0103)
Do I need to reference other dll's besides acmgd.dll and acdbmgd.dll?
Chuck Gabriel
Re: Xref Tools
« Reply #2 on: July 09, 2008, 02:53:48 PM »
Sorry.  I guess I should have mentioned that this was coded against the AutoCAD 2009 .NET API and that a reference to System.Windows.Forms is also required.
Thanks for taking a look at it, by the way.
« Last Edit: July 09, 2008, 02:57:37 PM by Chuck Gabriel »
FengK
Re: Xref Tools
« Reply #3 on: July 09, 2008, 04:13:40 PM »
Do you mean the code won't work with earlier releases of AutoCAD? (I tested it with AutoCAD 2008). Btw, I did reference System.Windows.Forms.
Chuck Gabriel
Re: Xref Tools
« Reply #4 on: July 09, 2008, 10:47:41 PM »
It uses at least one feature that I know doesn't exist in AutoCAD 2007.
That particular overload of ReadDwgFile doesn't exist in the 2007 API.  I'm not sure about 2008.
« Last Edit: July 10, 2008, 08:30:36 AM by Chuck Gabriel »
FengK
Re: Xref Tools
« Reply #5 on: July 10, 2008, 01:14:41 AM »
My guess is it doesn't exist in AutoCAD 2008 either. I'll confirm it tomorrow. Thanks.
Chuck Gabriel
Re: Xref Tools
« Reply #6 on: July 10, 2008, 06:37:47 AM »
Here is what I've used in the past.  This overload is deprecated according to the 2009 docs.
db.ReadDwgFile(fileName, System.IO.FileShare.Read, false, string.Empty);
FengK
Re: Xref Tools
« Reply #7 on: July 10, 2008, 01:18:13 PM »
This works with AutoCAD 2008. And the original overloaded version does not seem to available in 2008. Attached is from acad_mgd.chm for version 2008.
The OpenXrefs command doesn't seem to do anything.
Thanks Chuck.
Chuck Gabriel
Re: Xref Tools
« Reply #8 on: July 10, 2008, 02:25:38 PM »
I know there has been a lot of grumbling about 2009, but I will say this.  The documentation for the managed API is a lot better in 2009.
Are your xrefs relative-pathed by any chance?  I ask because the following line might cause it to to seem like a no-op if I've gotten my path resolution code wrong:
I can't remember whether I ever actually got around to testing this bit:
  string hostPath =
Thanks again for looking at it Kelie.
« Last Edit: July 10, 2008, 02:35:06 PM by Chuck Gabriel »
FengK
Re: Xref Tools
« Reply #9 on: July 10, 2008, 09:33:29 PM »
Yes. I prefer using relative paths.
Change "..\\" to ".\\" fixes the problem.
My pleasure. You've done the hard work and I get to learn a little bit of C#.
Glenn R
Re: Xref Tools
« Reply #10 on: July 11, 2008, 04:36:18 AM »
Hey Chuck,
Nice stuff - especially the relative path resolution. Can you try your bind function on the drawings I posted in this thread and see what happens please?
Cheers,
Glenn.
Chuck Gabriel
Re: Xref Tools
« Reply #11 on: July 11, 2008, 07:12:54 AM »
I should have thought of that.  Thanks for the tip.
Hey Chuck,
Cheers,
Glenn.
I'll try it when I get home.
Chuck Gabriel
Re: Xref Tools
« Reply #12 on: July 11, 2008, 10:36:12 AM »
I just realized I'm not going to be able to do this.  The function I used isn't available in 2007 and my trial of 2009 has expired.
It's Alive!
  • Retired
  • AKA Daniel
Re: Xref Tools
« Reply #13 on: July 12, 2008, 02:26:07 PM »
You do very nice programming Chuck!
The only thing I might consider changing is, the function filterXrefIds()  assigns the variable ‘Database db’ that’s not used.
Chuck Gabriel
Re: Xref Tools
« Reply #14 on: July 12, 2008, 02:44:47 PM »
Thanks.
I wonder where I was planning on going with that.  Thanks for pointing it out.
