Author Topic: CAD version without opening the drawing?  (Read 9004 times)
tedg
« Reply #15 on: December 16, 2014, 09:50:29 AM »
Holy Thread Resurrection....
I tried the link to get to the program on this thread, and I get a UK Adidas shopping web page.
I tried several times, different ways.
Does anyone have a better link, or a better program or suggestion to find the version of AutoCAD while browsing though hundreds of .dwg files?
Thanks in advance.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Re: CAD version without opening the drawing?
« Reply #16 on: December 16, 2014, 09:57:31 AM »
This function could be called by an appropriate program to query a set of drawings in a directory.
rkmcswain
« Reply #17 on: December 16, 2014, 10:19:07 AM »
You can open the drawing in Notepad and the first line will give you the drawing version.
That is what I always do.
AC1027 AutoCAD 2014
AC1027 AutoCAD 2013
AC1024 AutoCAD 2010/2011/2012
AC1021 AutoCAD 2007/2008/2009
AC1018 AutoCAD 2004/2005/2006
AC1015 AutoCAD 2000/2000i/2002
AC1014 Release 14
AC1012 Release 13
AC1009 Release 11/12
AC1006 Release 10
AC1004 Release 9
AC1003 Version 2.60
AC1002 Version 2.50
AC1001 Version 2.22
AC2.22 Version 2.22
AC2.21 Version 2.21
AC2.10 Version 2.10
AC1.50 Version 2.05
AC1.40 Version 1.40
AC1.2 Version 1.2
MC0.0 Version 1.0
(Partial copy from http://autodesk.blogs.com/between_the_lines/autocad-release-history.html )
tedg
« Reply #18 on: December 16, 2014, 10:30:45 AM »
Thanks guys.
RK, I saw this before (you had a post in AUGI too), very valuable, but trying to do this without "opening" the file(s).
Lee, I'll see what I can do with this, looks promising.
Thanks again.
rkmcswain
« Reply #19 on: December 16, 2014, 10:43:23 AM »
Apologies. I thought you meant "open" using CAD.
I didn't realize you meant every kind of "open"
 :angel:
tedg
« Reply #20 on: December 16, 2014, 10:53:53 AM »
 :angel:
LOL, no problem.
The problem I'm trying to help with is we have like 400+ dwg files, and some (we're told) are version 2007 (which they're not supposed to be) and we want to browse them and find out what version they are.
I guess opening them in notepad is not much different then finding properties on them.
Lee's link is helpful, but I don't quite know what to do with it, a bit over my head.
The program mentioned in this thread seemed promising for browsing to the files and seeing what version they are.
tedg
« Reply #21 on: December 16, 2014, 10:58:44 AM »
Update...
I've been told there is an windows explorer add-on that will show the file version as one of the options that can be shown.
I don't know what it is yet, but I saw the results on someones's screen.
I'll keep you posted.
PHX cadie
« Reply #22 on: December 16, 2014, 12:16:16 PM »
Update...
Pls do, that would be cool
Acad 2013 and XM
Back when High Tech meant you had an adjustable triangle
hugha
« Reply #23 on: December 17, 2014, 05:23:17 AM »
http://www.mythicsoft.com/filelocatorlite
This is a brilliant product.  Their Pro version has even more flexibility:
http://www.mythicsoft.com/filelocatorlite/features
basically once you've set a set of search trees and filename masks and optionally a search string just hit start and wait a little. You'll have your list within minutes of installation (within seconds with practice, once your MRUs get populated).
You can then open the files directly off the found list or explore the containing directory ...
I use the Lite version constantly checking file dates to monitor workflow. Did I say I think it's brilliant?
hth
Hugh
« Last Edit: December 17, 2014, 05:29:28 AM by hugha »
tedg
« Reply #24 on: December 17, 2014, 07:59:01 AM »
Update...
This is what I was referring to, it is an Autodesk exchange App.
You need an Autodesk account, and you can download a free trial version.
It gives you lots of options to show AutoCAD data in your explorer columns, I just chose "DWG version" but there's more.
https://apps.exchange.autodesk.com/ACD/Detail/Index?id=appstore.exchange.autodesk.com:dwgcolumnsforexplorerfree:en
Hope this helps someone, it did what I needed it to do.
PS, thanks to hugha for posting another option too.
