Author Topic: THICK THIN 3D die cast models  (Read 6863 times)
SDETERS
« on: April 27, 2006, 02:33:19 PM »
I am working on an aluminum Die cast part 3D model.  I need to check this model for thin and thick sections.  The 3D software we have today does not have this function.  Is there any software out there that can do this for me.  I have some thoughts that solidworks has something similar to this.  Is there any other software out there that can do this?  Thanks
Shane
Tramber
Re: THICK THIN 3D die cast models
« Reply #1 on: April 27, 2006, 04:33:21 PM »
What about Alibre ? It's the cheapest in this family.
SDETERS
« Reply #2 on: April 27, 2006, 05:55:07 PM »
Nope they do not have this kind of tool :-(
Any other thoughts?
Thanks for the info
Good Day
« Reply #3 on: April 27, 2006, 06:54:00 PM »
IronCAD is a very capable modeller, perhaps you could check it out.
Using vanilla AutoCAD you could cut sections through the 3d solid where required and notate them(?)
- John Carmack
- J.R.R. Tolkien
SDETERS
« Reply #4 on: April 28, 2006, 08:20:01 AM »
Yes I could create cross sections or Dynamic clip the model and look for thick thin sections.  Very time consuming.  Solidworks has a program that automatically checks for these conditions per your input criteria and highlights the model surfaces in different colors per wall thickness.  I was trying to see if there is any other software programs out there that would do this?
Shane
SDETERS
« Reply #5 on: April 28, 2006, 05:56:54 PM »
I am going to answer my own post
http://www.geometricsoftware.com/technologies/Thickness_Analyzer/thickness_checker.htm
This is what I have found so far
Thanks for all the info
Shane
« Reply #6 on: April 28, 2006, 07:03:33 PM »
Ahh, I see, more for analysis than notation or viewing :).
- John Carmack
- J.R.R. Tolkien
