Author Topic: ADT 2006 Walls...  (Read 2547 times)
Russ
ADT 2006 Walls...
« on: March 20, 2006, 10:14:47 AM »
Anyone have any idea why when I paste my 2nd floor or attach it as an xref into my 1st floor.dwg the walls won't show up? In the layer manager all looks on and ok. Argh...
David Hall
  • Automatic Duh Generator
Re: ADT 2006 Walls...
« Reply #1 on: March 21, 2006, 08:14:58 AM »
PS or MS?  Any frozen viewport layers your not seeing?
They say money can't buy happiness, but it can buy Bacon and that's a close second
DinØsaur
  • Certified Bovine Scat Distributor...I lay it on THICK
  • But I don't WANT a Day Job
« Reply #2 on: March 21, 2006, 08:40:51 AM »
I don't use this program and this may apply only to Revit.  If so, I apologizing for butting in.  I seem to remember a similar problem being caused by the visibility of an object being controlled by its being above or below a certain level or object.
Stephen R. Sherrill,
The DinØsaur
Civil 3D Specialist Emeritus
YAY ME !!!  I made it out alive !
pochrist
« Reply #3 on: March 22, 2006, 03:45:17 PM »
Check your Cut Planes , if you can see them in a 3D Isoview and not in plan, then your Display represenation needs to be modified, Perferably in a Paper space viewport, 1 Viewport for 1st floor and 1 for 2nd floor. HTH
