Author Topic: Adding a row to a table  (Read 11591 times)
Joel Roderick
« on: March 14, 2006, 06:35:15 PM »
Haven't posted here in a while, and I am new to .net...
I am trying to add a row to an existing table.  I am trying to not use the com interop (my crutch).
I am not sure if I am using transactions properly because I keep crashing AutoCAD when I try to open the object for write.  If I open the object for read, it doesn't crash.  Any help is much appreciated...
Here is what I have so far:
Dim editor As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim pOptions As PromptEntityOptions = New PromptEntityOptions("Select a table: ")
Dim pResults As PromptEntityResult = editor.GetEntity(pOptions)
Dim tbl As Table
Dim trans As Transaction
trans = HostApplicationServices.WorkingDatabase().TransactionManager.StartTransaction()
tbl = trans.GetObject(pResults.ObjectId, OpenMode.ForWrite)    '<---- ****crashes here****
tbl.InsertRows(1, 1.0, 1)
trans.Commit()
trans.Dispose()
Re: Adding a row to a table
« Reply #1 on: March 14, 2006, 07:26:04 PM »
It may be a casting thing, do you cast in vb?(maybe pResults.ObjectId as Table or similar??)
IOW, it's trying to turn an Object into a Table without seeing if it fits.
This is only a guess and maybe something to work with 'till someone has a better idea.
hth.
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: March 14, 2006, 09:10:51 PM »
or possibly something like
Table tbl = (Table)trans.GetObject(pResults.ObjectId, OpenMode.ForWrite);
aside;
Great to see you here Joel. We are still in our infancy as a group, and possibly won't be able to solve all issues.
Hope you Enjoy the site.
Draftek
« Reply #3 on: March 15, 2006, 08:01:29 AM »
In addition, you may need to lock the document depending on your command type flags or the mode your command runs in (like modelss or inside events).
The document must always be locked before modification of entities.
Joel Roderick
« Reply #4 on: March 15, 2006, 09:11:09 AM »
Thanks Draftek!
Looks like locking the document worked.  Now that I am passed that hurdle, let's see what other damage I can do!
Here is the updated code:
Dim tbl As Table
editor.Document.LockDocument()
trans.Commit()
trans.Dispose()
LE
« Reply #5 on: March 15, 2006, 09:28:08 AM »
Nothing related, but maybe useful and not mine [no net yet]
<CommandMethod("MyTable")> _
  Public Shared Sub MyTableCmd()
        Dim mTable As Table
        Dim rowt As RowType
        Dim bt As BlockTable
        Dim btr As BlockTableRecord
        Try
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim objId As ObjectId = db.BlockTableId
            bt = objId.Open(OpenMode.ForRead)
            objId = bt.Item(btr.ModelSpace)
            btr = objId.Open(OpenMode.ForWrite)
            mTable = New Table()
            btr.AppendEntity(mTable)
            btr.Close()
            bt.Close()
            mTable.InsertColumns(0, 12, 1)
            mTable.InsertColumns(1, 40, 1)
            mTable.InsertColumns(2, 40, 1)
            mTable.InsertColumns(3, 40, 1)
            mTable.InsertColumns(4, 16, 1)
            mTable.InsertColumns(5, 30, 1)
            mTable.InsertRows(0, 8, 10)
            mTable.SetTextHeight(3, rowt.DataRow)
            mTable.SetTextString(0, 0, "TEST")
            mTable.SetTextString(0, 1, "TEST")
            mTable.SetTextString(0, 2, "TEST")
            mTable.SetTextString(0, 3, "TEST")
            mTable.SetTextString(0, 4, "TEST")
            mTable.SetTextString(0, 5, "TEST")
            mTable.SetTextString(1, 0, "TEST")
            mTable.SetTextString(1, 1, "TEST")
            mTable.SetTextString(1, 2, "TEST")
            mTable.SetTextString(1, 3, "TEST")
            mTable.SetTextString(1, 4, "TEST")
            mTable.Position = New Point3d(180, 80, 0)
            mTable.Close()
        Catch
        Finally
        End Try
« Reply #6 on: March 16, 2006, 04:03:52 AM »
Joel, This works for me ..
    public class Class1
        public void
       TableTest()
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            // restrict selection to Table only
            PromptEntityOptions entOpt = new PromptEntityOptions("\nSelect Table: ");
            entOpt.SetRejectMessage("\nOnly Tables may be selected.");
            entOpt.AddAllowedClass(typeof(Table), true);
            //Start the selection ...
            PromptEntityResult entRes = ed.GetEntity(entOpt);
            //If a Table was successfully selected, proceed
            if (entRes.Status != PromptStatus.OK) {
                return;
            try {
                using (Transaction trans = db.TransactionManager.StartTransaction()) {
                    Table tbl = (Table)trans.GetObject(entRes.ObjectId, OpenMode.ForWrite, true);
                    tbl.InsertRows(1, 1.0, 1);
                    trans.Commit();
                    ed.WriteMessage("\nPosition : " + tbl.Position.ToString());
                    ed.WriteMessage("\nNumber of Columns : " + tbl.NumColumns.ToString());
                    ed.WriteMessage("\nNumber of Rows    : " + tbl.NumRows.ToString());
                    ed.WriteMessage("\nWidth  : " + tbl.Width.ToString());
                    ed.WriteMessage("\nHeight : " + tbl.Height.ToString());
            } catch (Autodesk.AutoCAD.Runtime.Exception acEx) {
                ed.WriteMessage("\nError: " + acEx.Message);
                return;
Command: Test0316
Select Table:
Nothing Selected.
Select Table:
Select Table:
Position : (1107.35495576984,2.99726696006678,0)
Number of Columns : 5
Number of Rows    : 9
Width  : 317.5
Height : 83
« Last Edit: March 16, 2006, 04:07:12 AM by Kerry Brown »
« Reply #7 on: March 16, 2006, 04:19:42 AM »
Just a note :
If I try this ;
Table tbl = trans.GetObject(entRes.ObjectId, OpenMode.ForWrite, true);instead of this ;
Table tbl = (Table)trans.GetObject(entRes.ObjectId, OpenMode.ForWrite, true);I get this compile error, as I expected.
Error   1
Cannot implicitly convert type 'Autodesk.AutoCAD.DatabaseServices.DBObject' to 'Autodesk.AutoCAD.DatabaseServices.Table'.
An explicit conversion exists (are you missing a cast?)
:\VisualStudio2005\Projects\KDUB\theSwamp\TestTable\TestTable\Class1.cs   105   33   TestTable
Joel Roderick
« Reply #8 on: March 16, 2006, 03:00:07 PM »
Luis, Kerry,
Thanks for the replies.  It actually helped me to understand more about how .net handles things vs VB/A.
I noticed that the code that Luis posted doesn't use a transaction.  I am still a little confused as to the advantages of a transaction when you just want to do something simple.  Maybe I should start another topic...
LE
« Reply #9 on: March 16, 2006, 03:06:37 PM »
Luis, Kerry,
Hi Joel;
The reason is that when you use transactions, you do not have to close the objects, is the same way as using smart pointers...
But, I do not write code in C# yet... only ARX [right now I am trying to write this in ObjectARX]
« Reply #10 on: March 16, 2006, 03:17:24 PM »
Hi Joel,
Joel Roderick
« Reply #11 on: March 16, 2006, 03:59:13 PM »
Thanks Kerry,
I must have read that document a dozen times and never saw that section...
LE
« Reply #12 on: March 16, 2006, 08:19:20 PM »
Hi Kerry;
In your TableTest() function, when you add the row(s), are they shown automatically on the selected Table?, or you have to grip the table and stretched and after that, the new row(s) are shown?
Thanks.
« Reply #13 on: March 16, 2006, 08:50:49 PM »
Showing automagically.
LE
« Reply #14 on: March 16, 2006, 08:54:03 PM »
Thanks, I did the test on arx, but have not found the method to do that magic.... part  :-(
It will add the row, but I have to select after that [grip] the Table to show the new added row.
