Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
CAD Forums
CAD General
Topic:
Hatch problem
« previous
next »
Print
Pages: [
1
2
3
All
Go Down
Author
Topic: Hatch problem (Read 8458 times)
42
Bull Frog
Hatch problem
on:
February 17, 2004, 09:56:57 AM »
Have a look at this drawing of a hatch problem. The one on the left is correct. What has happened to the righthand one?
http://theswamp.org/lilly.pond/42/hatch.dwg
It seems to be broken, the effect is the same for all hatch pattens.
Logged
Technical Director
Hunters South Architects
daron
Guest
Hatch problem
Reply #1 on:
February 17, 2004, 10:01:01 AM »
I don't know, but using match fixed it.
Logged
42
Bull Frog
Hatch problem
Reply #2 on:
February 17, 2004, 10:04:10 AM »
Unfortunately using match does not fix it on my machine, although I match the left one into the right one.
Logged
Technical Director
Craig
Guest
Hatch problem
Reply #3 on:
February 17, 2004, 10:07:37 AM »
One thing I noticed about the two is the following
One on the left
(70 . 0) (71 . 0) (91 . 4) (92 . 5) (93 . 4) (72 . 1)
One on the right
(70 . 0) (71 . 1) (91 . 1) (92 . 1) (93 . 4) (72 . 1)
71 - Associativity flag (associative = 1; non-associative = 0)
91 - Number of boundary paths (loops)
92 - Boundary path type flag (bit coded):0 = Default; 1 = External; 2 = Polyline;4 = Derived; 8 = Textbox; 16 = Outermost
72 - Edge type (only if boundary is not a polyline):1 = Line; 2 = Circular arc; 3 = Elliptic arc; 4 = Spline
93 - Number of edges in this boundary path
When I redid the same hatch on my machine they came in identical
Hope this helps some
Logged
42
Bull Frog
Hatch problem
Reply #4 on:
February 17, 2004, 10:29:25 AM »
That’s beautiful Craig, but I do not have a Scooby Doo what it means. Well yes I know that it refers to the hatch construction, but beyond that no clue. The hatch works fine in other drawings.
Logged
Technical Director
daron
Guest
Hatch problem
Reply #5 on:
February 17, 2004, 10:33:05 AM »
audit the drawing?
Logged
42
Bull Frog
Hatch problem
Reply #6 on:
February 17, 2004, 10:33:28 AM »
Yep done that
Logged
Technical Director
daron
Guest
Hatch problem
Reply #7 on:
February 17, 2004, 10:35:52 AM »
wblock it to another name and rename?
Lastly, start over?
Logged
42
Bull Frog
Hatch problem
Reply #8 on:
February 17, 2004, 10:44:45 AM »
Done that but no dice on effect on the hatch.
Not an option 3.5MB drawing.
Logged
Technical Director
Global Moderator
Seagull
Hatch problem
Reply #9 on:
February 17, 2004, 10:47:49 AM »
I noticed that the one on the right is associative.
Your Scale factor does not work for me. Maybe my
arconc hatch is different but when I edit the hatch on the right
change the scale to 20 it redraws as correct.
Logged
daron
Guest
Hatch problem
Reply #10 on:
February 17, 2004, 10:54:19 AM »
Have you tried deleting the bad hatch, redrawing its boundary, then re-hatching it as non-associative. It seems to be associative when listing it, but doen't appear to be associative when selecting it.
Logged
Craig
Guest
Hatch problem
Reply #11 on:
February 17, 2004, 10:57:42 AM »
Well I found something else that might be your problem. Did you create the rectangles differently? Notice the difference between the two LWPOLYLINE's?
The left one
((-1 . <Entity name: 40a0be30>) (0 . "LWPOLYLINE") (330 . <Entity name: 40a86c10>)
The right one
((-1 . <Entity name: 40a0be20>) (0 . "LWPOLYLINE") (5 . "9AC") (102 . "{ACAD_REACTORS") (330 . <Entity name: 40a0be28>)
102 - Start of application-defined group "{application_name". For example, "{ACAD_REACTORS" indicates the start of the AutoCAD persistent reactors group. This group exists only if persistent reactors have been attached to this object.
Logged
42
Bull Frog
Hatch problem
Reply #12 on:
February 17, 2004, 10:58:10 AM »
I rehatched both areas in the original drawing using associative and non-associative hatching, it makes no differance.
Daron, this also makes on differance. I can draw a new hatch boundary and either hatch it by point or object. What is frustrating is that hatching done earlier is fine.
Logged
Technical Director
42
Bull Frog
Hatch problem
Reply #13 on:
February 17, 2004, 11:03:00 AM »
Craig. I can copy a rectangle that containes correct hatch, rehatch the second rectangle and obtain the incorrect hatch.
Logged
Technical Director
daron
Guest
Hatch problem
Reply #14 on:
February 17, 2004, 11:08:51 AM »
It seems that you have something setting reactors in your drawing, as Craig pointed out. I had your drawing open and was in here. I went in to cad and noticed it had frozen up. Has anybody else experienced this?
List your rectangles. Are they containing any reactors? Are they both unassociative?
Logged
Print
Pages: [
1
2
3
All
Go Up
« previous
next »
CAD Forums
CAD General
Topic:
Hatch problem
