Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Triangulation
« previous
next »
Print
Pages:
1
2
3
4
All
Go Down
Author
Topic: Triangulation (Read 13473 times)
ymg
Guest
Re: Triangulation
Reply #45 on:
February 03, 2014, 01:20:20 AM »
Bullah,
Your modified code was working. However a point does not show much unless you
change DDPTYPE.
Here I have modified so that the points are entmake'd and kept the list in the command line:
Code - Auto/Visual Lisp:
[Select]
;; Given the ename of a 3DFACE ;
;; Returns List of 3 unique points forming that face ;
defun
3df
pl
en
defun
distinct
l
if
l
cons
car
l
distinct
vl-remove
car
l
l
setq
ent
entget
en
l
distinct
mapcar
lambda
a
cdr
assoc
a ent
10
11
12
13
;; Given 2 List ;
;; Returns List of Elements Common to Both List. ;
defun
common
l1 l2
if
l1
if
member
car
l1
l2
cons
car
l1
common
cdr
l1
l2
common
cdr
l1
l2
;; Given a Selection Set of Entities ;
;; Returns List of ename ;
defun
ss
enl
ss
i l
if
ss
repeat
setq
i
sslength
ss
setq
l
cons
ssname
ss
setq
i
1-
i
l
defun
crossproduct
u v
list
cadr
u
caddr
v
cadr
v
caddr
u
car
v
caddr
u
car
u
caddr
v
car
u
cadr
v
car
v
cadr
u
defun
getz
p p1 p2 p3
n
setq
p
list
car
p
cadr
p
0
n
crossproduct
mapcar
p2 p1
mapcar
p3 p1
list
car
p
cadr
p
apply
mapcar
n
mapcar
p1 p
caddr
n
;; Return the maximum extent along the X of Selection Set of 3DFACE ;
defun
maxtr
ss
i ent tmp bb rtn
setq
rtn
0
repeat
setq
i
sslength
ss
setq
ent
entget
ssname
ss
setq
i
1-
i
tmp
mapcar
lambda
a
cdr
assoc
a ent
10
11
12
13
bb
list
apply
mapcar
cons
min
tmp
apply
mapcar
cons
max
tmp
rtn
max
rtn
caadr
bb
caar
bb
Función zpto
defun
c:zpto
p enl enl1 enl2 tr
setvar
"osmode"
0
setq
maxt
maxtr
ssget
"_X"
0
"3DFACE"
while
setq
p
getpoint
\n
Pick a Point: "
;Searching For The Repeated 3DFACE
setq
enl1
ss
enl
ssget
"_F"
list
p
list
car
p
maxt
cadr
p
0
"3DFACE"
enl2
ss
enl
ssget
"_F"
list
p
list
car
p
maxt
cadr
p
0
"3DFACE"
cond
setq
enl
common enl1 enl2
setq
tr
3df
pl
car
enl
p
getz p
car
tr
cadr
tr
caddr
tr
entmakex
list
0
"POINT"
cons
10
p
princ
\n
Point on 3dFace: "
princ
p
t
princ
\n
Point is Outside of TIN"
Last Edit: February 03, 2014, 02:33:37 AM by ymg
Logged
bullah
Guest
Re: Triangulation
Reply #46 on:
February 04, 2014, 10:48:51 PM »
"terima kasih tuan" thank you sir
Logged
ymg
Guest
Re: Triangulation
Reply #47 on:
February 04, 2014, 11:29:01 PM »
Terima kasih kembali, Bullah
Logged
Print
Pages:
1
2
3
4
All
Go Up
« previous
next »
Code Red
Topic:
Triangulation
