Author Topic: ( LDT ) Error message  (Read 2887 times)
« on: January 17, 2006, 08:34:01 AM »
Has anyone ever seen this one?
Warning: Inhibiting simultaneous loading of multiple versions of
application*Cancel*
Doesn't seem to affect the way the program runs.
Autodesk Land Desktop 2005 SP 1
Lin-Z
Re: ( LDT ) Error message
« Reply #1 on: January 17, 2006, 10:14:07 AM »
A quick search of the message in the AD discussion groups yields these 2 that may apply:
http://discussion.autodesk.com/thread.jspa?messageID=4834225
http://discussion.autodesk.com/thread.jspa?messageID=4280645
« Reply #2 on: January 17, 2006, 12:09:12 PM »
Thanks Lin-Z.
« Reply #3 on: January 18, 2006, 08:14:02 PM »
Sounds as if you might try turning OFF object detect and command invoking
and then load the drawing in question.  If the error persist, this might suggest
that you need to open a Land drawing and attach to the C3D drawing and
query everything back into the Land of Land.
If turning off Object Detect/Command Invoke works let us know.
And or send me a sample of the afflicted file to dissect in the lab.
Can we be sure that they are the same version, 2006, 2005?
« Last Edit: January 19, 2006, 09:21:52 AM by mjfarrell »
« Reply #4 on: January 19, 2006, 12:44:22 PM »
Thanks Michael. If I can find the problem dwg again I'll give that a try.
BTW, my sig is incorrect, I'm now only using LDT 2005.
