Author Topic: Already choosen...or is it?  (Read 4039 times)
rude dog
« on: February 11, 2004, 02:33:23 PM »
Need help understanding how code can search a list and find items that have been choosen (and prompt "duplicate objects will be ignored")  twice ...can any one offer a small simple routine for me to study...I have looked @ others code and the help menu but still can make the connection. :x
Matt Stachoni
Re: Already choosen...or is it?
« Reply #1 on: February 11, 2004, 02:36:18 PM »
Quote from: Rude Dog
Normally, the trick is to build the list using a test to see if it's a member already:
(if (not (member x lst))
  (setq lst (cons x lst))
However, I would need to see your routine to fully understand "have been chosen."
Do you mean selected, as in a selction set?
rude dog
« Reply #2 on: February 11, 2004, 03:03:53 PM »
Matt,
you hit it right on the head...please eloborate what each step does
(if and (not ...togethter kinda throw me  :oops:
daron
« Reply #3 on: February 11, 2004, 03:14:33 PM »
All if and not together means that if the test function returns true, not wrapped around it changes t to nil. So, if the member of x is NOT a lst(list) then set lst to cons...
« Reply #4 on: February 11, 2004, 03:37:04 PM »
Let me add to this. Break down the commands that Matt showed us and watch what happens.
 - create a list
Command: (setq lst '(1 2 3 4))
(1 2 3 4)
Command: (member 3 lst)
(3 4) <- notice member return something
- create 'x'
Command: (setq x 5)
5
Command: (member x lst)
nil <- nope x is _not_ in the list
Command: (not (member x lst))
T <- returns T (true) because 5 is not in the list
Command: (setq lst (cons x lst))
(5 1 2 3 4) <- construct a new list and add 'x' to it
- create 'x'
Command: (setq x 6)
6
- now put it all together
Command: (if (not (member x lst))(setq lst (cons x lst)))
(6 5 1 2 3 4)
Anonymous
« Reply #5 on: February 11, 2004, 04:02:43 PM »
Got it dude:D  :!:  :wink:
rude dog
« Reply #6 on: February 11, 2004, 04:03:53 PM »
me again....above
