Author Topic: Double click editing on / off ...  (Read 5520 times)
« on: January 09, 2006, 11:49:09 AM »
... I had a user this morning have want for the ability to turn on / off double click editing; this is what I wrote for him.
(defun c:DblClkOn ( )
        (zerop
            (vl-registry-read
                (strcat
                    "HKEY_CURRENT_USER\\"
                    (vlax-product-key)
                    "\\profiles\\"
                    (vla-get-activeprofile
                        (vla-get-profiles
                            (vla-get-preferences
                                (vlax-get-acad-object)
                    "\\General"
                "DoubleClickEdit"
        (command ".dblclkedit" "_on")
    (if (zerop (getvar "pickfirst"))
        (setvar "pickfirst" 1)
(defun c:DblClkOff ( )
        (eq 1
            (vl-registry-read
                (strcat
                    (vlax-product-key)
                    "\\profiles\\"
                        (vla-get-profiles
                    "\\General"
                "DoubleClickEdit"
        (command ".dblclkedit" "_off")
Cheers.
whdjr
Re: Double click editing on / off ...
« Reply #1 on: January 09, 2006, 12:12:11 PM »
Just out of curiosity could you set this up like a boolean operation, if it's on turn it off and vice versa.  I've seen similar functions with with system variables.
« Reply #2 on: January 09, 2006, 12:35:54 PM »
As you wish ...
(defun c:DblClk ( )
        (   (zerop
                (vl-registry-read
                    (strcat
                        (vlax-product-key)
                        "\\profiles\\"
                            (vla-get-profiles
                        "\\General"
                    "DoubleClickEdit"
        ((command ".dblclkedit" "_off"))
whdjr
« Reply #3 on: January 09, 2006, 12:53:11 PM »
Now doesn't that just look cleaner?   :-)
LE
« Reply #4 on: January 09, 2006, 12:55:32 PM »
? why not just use the built in command.
« Reply #5 on: January 09, 2006, 01:07:02 PM »
Because said command does not automatically force pickfirst to 1; a dumb oversite on Autodesk's part if you ask me.
Ok, so you didn't ask me. Oh well.
LE
« Reply #6 on: January 09, 2006, 01:18:00 PM »
It makes sense now...
GDF
« Reply #7 on: January 09, 2006, 02:54:20 PM »
Works for 2006 also.
;;; James Buzbee's Double Click Reactor
;;; 2000i 2002 and 2004
;;; This is the main callback function where you'll define
;;; what command is fired over what object - see the command list
;;; If multiple objects are gripped and the command does not support
;;; multiple editing you will be prompted for an entity to edit.
(defun jb:beginDoubleClick  (reactorObject Listofsomething / point obj owner ownerobj
                             command-list cmd gripset)
;;; added for error in 2004 - point returned from outside a
;;;  paperspace viewport throws an error.
  (if (vl-catch-all-error-p
        (vl-catch-all-apply 'trans (list (car Listofsomething) 0 1)))
    (princ "PaperSpace")
      (setq cmd     "_.PROPERTIES" ; command default
            point   Listofsomething
            obj     (car (nentselp (trans (car point) 0 1)))
            owner   (car (cadddr (nentselp (trans (car point) 0 1))))
            gripset (cadr (ssgetfirst))
            doc     (vlax-get (vlax-get-acad-object) "activedocument"))
      (if obj
        (progn ; this statement will determine if the object
    ; clicked over is an insert or not
          (cond (owner
                 (setq ownerobj
                        (strcase (vlax-get (vlax-ename->vla-object owner) "objectname"))))
                (t
                 (setq ownerobj
                        (strcase (vlax-get (vlax-ename->vla-object obj) "objectname")))))
          ;;Now set up your commands for the appropriate object
          ;;       Object               Command
          ;;(cons "ACDBBLOCKREFERENCE" "_.REFEDIT ")
          (setq command-list
                 (list (cons "ACDBBLOCKREFERENCE" "_.REFEDIT")
                       (cons "ACDBATTRIBUTE" "_.EATTEDIT")
                       (cons "ACDBMTEXT" "_.DDEDIT")
                       (cons "ACDBTEXT" "_.DDEDIT")
                       (cons "ACDBROTATEDDIMENSION" "_.DIM-ALL")
                       (cons "ACDBALIGNEDDIMENSION" "_.DIM-ALL")
                       (cons "ACDBORDINATEDIMENSION" "_.DIM-ALL")
                       (cons "ACDBDIAMETRICDIMENSION" "_.DIM-ALL")
                       (cons "ACDBRADIALDIMENSION" "_.DIM-ALL")
                       (cons "ACDB2LINEANGULARDIMENSION" "_.DIM-ALL")
                       (cons "ACDBLEADER" "_.LISO")
                       (cons "ACDBMLINE" "_.MLEDIT")
                       (cons "ACDBPOLYLINE" "_.LISO")
                       (cons "ACDBLINE" "_.LISO")
                       (cons "ACDBCIRCLE" "_.LISO")
                       (cons "ACDBSPLINE" "_.LISO")
                       (cons "ACDBPOINT" "_.LISO")
                       (cons "ACDBATTRIBUTEDEFINITION" "_.DDEDIT")
                       (cons "ACDBHATCH" "_.HATCHEDIT")
                       (cons "ACDBRASTERIMAGE" "_.IMAGEADJUST")
;;; architectural desktop commands
                       (cons "AECDBWALL" "_.PROPERTIES")
                       (cons "AECDBDOOR" "_.PROPERTYDATAEDIT")
                       (cons "AECDBWINDOW" "_.PROPERTIES")
                       (cons "AECDBWINDOWASSEMBLY" "_.PROPERTIES")
                       (cons "AECDBCURTAINWALLLAYOUT" "_.PROPERTIES")
                       (cons "AECDBSPACE" "_.PROPERTYDATAEDIT")
                       (cons "AECDBSTAIR" "_.PROPERTIES")
                       (cons "AECDBRAILING" "_.PROPERTIES")
                       (cons "AECDBMVBLOCKREF" "_.PROPERTIES")
                       (cons "AECDBOPENING" "_.PROPERTIES")
                       (cons "AECDBCEILINGGRID" "_.PROPERTIES")
                       (cons "AECDBCOLUMNGRID" "_.PROPERTIES")
                       (cons "AECDBSLAB" "_.PROPERTIES")
                       (cons "AECSDBMEMBER" "_.PROPERTIES")
                       (cons "AECDBMASSELEM" "_.PROPERTIES")
                       (cons "AECDBROOF" "_.PROPERTIES")
                       (cons "AECDBROOFSLAB" "_.PROPERTIES")
                       (cons "AECDBCAMERA" "_.PROPERTIES")
                       (cons "AECDBSCHEDULETABLE" "_.PROPERTIES")))
;;; get the command
          (foreach
                 x  command-list
            (if (= (car x) ownerobj)
              (setq cmd (cdr x))))
;;; make adjustment to command
          (cond ((= cmd "_.REFEDIT")
                 (setq cmd "_.refedit (princ (cdr (nentselp (trans(car point)0 1)))) "))
                ((= cmd "_.ATTEDIT") (setq cmd "_.attedit (princ obj) "))
                ((= cmd "_.EATTEDIT") (setq cmd "_.eattedit (princ obj) "))
                (t (setq cmd (strcat cmd " "))))
          (vla-sendcommand doc cmd))))))
(defun jb:LoadDoublClickReactor  (/)
  (if (/= (type jbDoubleClickReactor) 'VLR-Mouse-Reactor)
    (setq jbDoubleClickReactor
           (VLR-Mouse-Reactor
             nil
             '((:VLR-beginDoubleClick . jb:beginDoubleClick))) ;_ end of vlr-editor-reactor
  (if (not (vlr-added-p jbDoubleClickReactor))
    (vlr-add jbDoubleClickReactor))
;;; Unload acdblclkedit.arx in favor of jb's Expanded Double Click editing!
  (if (member "acdblclkedit.arx" (arx))
    (arxunload "acdblclkedit.arx" nil))
  (princ))
