The northern part of my company uses Microstation while we use Acad, when I saw that they had 2 twenty-one inch monitors on their desktop I thought "these people are sooo spoiled"
Then I attended Microstation training and started using it some, I quickly concluded that it is almost impossible to work with Microstation if you only have one monitor. By the time you have to have all the toolbars and dialog boxes, the amount of screen space left is the size of a postage stamp. I started trying to program around some of this using VBA and bumped into a serious (at least in my opinion) bug. I could not get tags (attributes) to accept values fed from variables. The only good thing was Bentley admitted this was a bug (something autodesk would never do) and said they would address it.
On a slightly separate note, Why do the add-on type products have their own commands? This is confusing as hell! If you're using these commands, use these move, copy, etc.. but if you are using this, use this move, copy, etc.. With multiple add-ons I forget where I'm at and seem to try and use the wrong ones. Why can't move be move, regardless of the object?
