Author Topic: Mtext wrap or hard return?  (Read 15475 times)
hudster
« on: December 07, 2005, 12:34:46 PM »
Which do you prefer to use Word wraps or Hard returns?
jonesy
  • SuperMod
Re: Mtext wrap or hard return?
« Reply #1 on: December 07, 2005, 12:39:26 PM »
I prefer word wrap, but sometimes in 2002 we need to do a numbered list, and the quickest way we have found of doing that is to put in hard returns (I bet someone here has a better way to do that)
Greg B
  • Tell me a Joke!
« Reply #2 on: December 07, 2005, 01:37:17 PM »
I know I don't use AutoCAD but I would thing with text wrap you might have it wrapped where you don't want it to.
deegeecees
« Reply #3 on: December 07, 2005, 02:23:44 PM »
I always hard return. Alot of times AutoCADs text editor doesn't show text as WYSIWYG, and using any external editor just aint as fast. So, I hard return on new lines. Haven't encountered any problems.
« Reply #4 on: December 07, 2005, 02:26:40 PM »
Do I get points subtracted if I answer 'It depends on the nature of the text body' ?
deegeecees
« Reply #5 on: December 07, 2005, 02:37:29 PM »
Can I retract my last post? Of course I can. But I should've said that ^
hyposmurf
« Reply #6 on: December 07, 2005, 02:50:04 PM »
I prefer it hard most the time.
Sdoman
« Reply #7 on: December 07, 2005, 03:25:35 PM »
Hard returns for
leader notes to
precisely control
text breaks
Word wrap for long winded drawing notes. Having said that, 98% of our mtext is leader text.
whdjr
« Reply #8 on: December 07, 2005, 04:16:50 PM »
I'm with Kerry on this one.  It depends on the situation.
Mtext by its design is a multi-line paragragh style.  Most paragraphs don't have hard returns however there are times when you want things to be associated together yet other things seperated within the same piece of text.
Kate M
« Reply #9 on: December 08, 2005, 02:40:20 PM »
Hard returns for
leader notes to
precisely control
text breaks
What he said. :-) Also word wrap for numbered lists (except where you need a new number).
nivuahc
« Reply #10 on: December 08, 2005, 02:47:21 PM »
Numbered lists are automagic in 2006
Word Wrap!
Word Wrap! :realmad:
Okay, not for leaders... but for EVERYTHING ELSE!  :realmad:
Dommy2Hotty
« Reply #11 on: December 08, 2005, 02:50:35 PM »
I SOOOO want to make a comment  :evil: ...but I'll be good  :angel:
whdjr
« Reply #12 on: December 08, 2005, 02:52:00 PM »
Could we have a third option that states "Both"?
Greg B
  • Tell me a Joke!
« Reply #13 on: December 08, 2005, 03:08:16 PM »
And a forth that states
I don't like AutoCAD
Dommy2Hotty
« Reply #14 on: December 08, 2005, 03:36:04 PM »
Sounds like somebodies got a case of the Mon...err...Thursdays
