Author Topic: Lab 01 Reworked ..  (Read 4974 times)
Lab 01 Reworked ..
« on: December 02, 2005, 06:47:49 PM »
Decided to rework the AutoCAD C# Labs < Thanks David :-) >
visit www.autodesk.com/developautocad and download the .NET training labs posted there.
I'm trying to establish a format that is in some regard tiered and scalable.
.. the classes in this particular module would be seperated into their own files within the project or solution as the code grows.
any comments ?
#region System using declarations
using System;
#endregion
#region AutoCAD Managed Wrappers using declarations
//// Assembly acdbmgd .. ObjectDBX.NET Managed Wrapper
//// Assembly acmgd .. Autocad.NET Managed Wrapper
#endregion
#region Alias using declarations
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
#endregion
[assembly: ExtensionApplication(typeof(ClassLibraryLab01.kwbLab01StartApp))]
[assembly: CommandClass(typeof(ClassLibraryLab01.Commands))]
namespace ClassLibraryLab01
    #region CommandClass
    public class
    Commands
        [CommandMethod("HelloWorld", CommandFlags.Modal)]
        public static void Command_Hello()
            Class1 tester = new Class1();
            //call a function of the object.
            tester.HelloWorld();
        [CommandMethod("ByeWorld", CommandFlags.Modal)]
        public static void Command_Bye()
            tester.ByeWorld();
    #endregion
    #region Class1
    public class
    Class1
        public void
        HelloWorld()
            Editor
                ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("Hello World");
        public void
        ByeWorld()
            Editor
            ed.WriteMessage("Goodbye World, I'm off to join the circus");
    #endregion
    #region Public class kwbLab01StartApp
    /// <summary>
    /// The entry point for AutoCAD.
    /// </summary>
    public class
    kwbLab01StartApp : IExtensionApplication
        public void
        Initialize()
            Editor
            ed.WriteMessage("\n  Testing Assembly kwbLab01 [kwb v:20051203]");
            ed.WriteMessage("\n  Type HelloWorld at the Command Line to Start ...");
            ed.WriteMessage("\n  Type ByeWorld at the Command Line to Finish ...");
        public void
        Terminate()
            // Does Nothing ... can't unload NET assembly ...
    #endregion
Re: Lab 01 Reworked ..
« Reply #1 on: December 02, 2005, 07:21:47 PM »
oh, and in case anyone was wondering, this is the actual first Lab solution as published :-
public class Class1
[CommandMethod("HelloWorld")]
public void HelloWorld()
« Last Edit: December 03, 2005, 07:40:34 AM by Kerry Brown »
