Author Topic: 'STR  (Read 3576 times)
rude dog
'STR
« on: February 04, 2004, 02:59:25 PM »
What is the 'STR in the statement below?.... I tried changing it to 'ABC (thinking I would get the same results) and the prompt came up as "NO ITS NOT"
but when I run it with the 'STR in the expression.... prompt reads
"YES ITS A STRING"
(defun C:STT ()
  (setq TEST "THIS IS A STRING")
  (if (= (type TEST) 'STR)
    (prompt "YES ITS A STRING")
    (prompt "NO ITS NOT")
daron
'STR
« Reply #1 on: February 04, 2004, 03:01:59 PM »
Test (type TEST). What is the result? In your case it is STR. Look at the help file for type. You should find your answer.
'STR
« Reply #2 on: February 04, 2004, 03:08:51 PM »
In AutoLISP every variable is assigned a type according to what is in the variable, for example, if you type:
(setq A "a")
The type of variable A is, is a STRing
(setq A 1)
The type of variable A is, is an INTeger
(setq A 1.0)
The type of variable A is, is a REAL (aka long)
(setq A '(0 1 2)
The type of variable A is, is a LIST
If you have a function and you check it, the value will be:
(setq A C:MYFUNCTION)
The type of variable A is, is an SUBRoutine
Do you get the idea?
rude dog
'STR
« Reply #3 on: February 04, 2004, 04:20:26 PM »
good enuf thanks :wink:
'STR
« Reply #4 on: February 04, 2004, 04:21:28 PM »
No problem....
