And to take one more step closer.
(defun c:test ()
(get-file-of-linetype "center")
(defun get-file-of-linetype (lt-name / lt-list file-names)
(setq lt-name (strcase lt-name))
(if (setq lt-list (get-line-types))
(foreach file-list lt-list
(if (member lt-name (mapcar 'strcase (cadr file-list)))
(setq file-names (cons (car file-list) file-names))
file-names
;; CAB 11/22/2005
;; returns a list of all linetypes found in all .lin files found
(defun get-line-types (/ path paths fname fnames fnamelist ltnames linetypelist
(defun getlinetypes (filename / file line str lst)
(if (setq file (open (findfile filename) "r"))
(while (setq line (read-line file))
(if (wcmatch line "`**")
(setq str (substr (substr line 1 (vl-string-search "," line)) 2)
lst (cons str lst)
(close file)
(reverse lst)
;; get a list of all ACAD paths
;; removes "." ".." and needs error checking
(setq paths (cdr (cdr (vl-directory-files nil nil -1))))
;; get a list of all file names .lin
(foreach path paths
(if (setq fnames (vl-directory-files path "*.lin"))
(setq fnamelist (append fnames fnamelist))
(foreach fname fnamelist
(if (setq ltnames (getlinetypes fname))
(setq linetypelist (cons (list fname ltnames) linetypelist))
linetypelist
