Author Topic: Expert Level Resetting to Zero  (Read 4186 times)
Odon
« on: February 04, 2004, 02:18:43 PM »
The Expert level keeps returning to 0 when I restart AutoCAD 2000i.   I've checked the programs I have in acad.lsp and none of them refer to this setting.  I also have searched the Autdesk support site and I checked the contents of the startup suite unsuccessfully.
Any suggestions?
Odon
« Reply #1 on: February 04, 2004, 02:26:07 PM »
How about the acad2000doc.lsp?
What happens if you put the following in your acad.lsp?
(setvar 'expert 4)
« Reply #2 on: February 04, 2004, 02:45:41 PM »
You also need to check in VBA routines, startup suite programs and the profile *.arg
« Reply #3 on: February 04, 2004, 02:50:25 PM »
Quote from: Keith
Quote from: Odon
« Reply #4 on: February 04, 2004, 02:54:57 PM »
Ok Mark ... so I have a problem comprehending what I read ... errr .... look at .....
I still think that the profile MIGHT be a starting point to look at.
Odon
« Reply #5 on: February 04, 2004, 03:15:05 PM »
Quote from: Mark Thomas
(setvar 'expert 4)
Did it set to (setvar "expert" 1) and it works fine.  Thanks.
Odon
« Reply #6 on: February 04, 2004, 03:18:04 PM »
Hey guys, I just took a look at the ... ahem .... help file and look at what I found ...
Quote from: Autodork
Type: Integer
Not saved
Initial value: 0
Controls whether certain prompts are issued.
0   Issues all prompts normally.
1   Suppresses "About to regen, proceed?" and "Really want to turn the current layer off?"
2   Suppresses the preceding prompts and "Block already defined. Redefine it?" (BLOCK) and "A drawing with this name already exists. Overwrite it?" (SAVE or WBLOCK).
3   Suppresses the preceding prompts and those issued by the LINETYPE command if you try to load a linetype that's already loaded or create a new linetype in a file that already defines that linetype.
4   Suppresses the preceding prompts and those issued by UCS Save and VPORTS Save if the name you supply already exists.
5   Suppresses the prompt, "That name is already in Use, redefine it?" issued by the -DIMSTYLE Save option when you supply the name of an existing dimension style.
When a prompt is suppressed by EXPERT, the operation in question is performed as though you entered y at the prompt. Setting EXPERT can affect scripts, menu macros, AutoLISP, and the command functions.
Note the fact that EXPERT is not saved AND it defaults to 0
Odon
« Reply #7 on: February 04, 2004, 04:52:19 PM »
Quote from: Keith
Type: Integer
Not saved
Initial value: 0
 :oops:
Odon
daron
« Reply #8 on: February 04, 2004, 05:00:50 PM »
Don't worry about it. Most people don't read the help file and half the time the help file isn't that great or is inaccurate.
Dent Cermak
« Reply #9 on: February 04, 2004, 06:26:49 PM »
My expert level is permanently set to "Are you sh**ing me !"
