I found this lisp on the web, it works in IntelliCAD without any DCL files so I'll probably use this.
;| REVCLOUD.LSP
Copyright (C) 1997 by Autodesk, Inc.
Permission to use, copy, modify, and distribute this software
for any purpose and without fee is hereby granted, provided
that the above copyright notice appears in all copies and
that both that copyright notice and the limited warranty and
restricted rights notice below appear in all supporting
documentation.
AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
UNINTERRUPTED OR ERROR FREE.
Use, duplication, or disclosure by the U.S. Government is subject to
restrictions set forth in FAR 52.227-19 (Commercial Computer
Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
(Rights in Technical Data and Computer Software), as applicable.
Last revision 10/02/97 Bob Abernethy, dba/CADesigner
Credits: Original Code, idea and concept by David Harrington
Bill Kramer, Q.C.
Phil Kreiker, Q.C.
Dominic Panholzer, Q.C.
Randy Kinsley, Error Control
Greg Robinson
Bob Abernethy, dba/CADesigner, Added Incremental numbered revision
callout triangle & Layer control
(defun input_integer (a b / c)
(setq a (strcat a " <"(rtos b 2 0)"> "))
(setq c (getint a))
(if (/= c NIL)
(setq b c)
(setq b b)
(setq incr 1)
(defun item (ent)
(cdr(car(entget(ent))))
(defun ERR (s)
(if (/= s "Function cancelled\n")
(if (= s "quit / exit abort")
(alert (strcat " >> Error << \n"))
(setvar "CLAYER" CL)
(setq *error* olderr)
(Defun C:REVCLOUD (/
ARC_DIST ;;radius of included arc
INC_ANGLE ;;included angle in degrees
LAST_PT ;;the last point just entered/shown
START_PT ;;where the cloud began
NEXT_PT ;;where we are going next
TMP ;;tempory holder for radius of bulge
(setq olderr *error* *error* err)
(setq ce (getvar "cmdecho"))
(setq blp (getvar "blipmode"))
(setq osm (getvar "osmode"))
(setvar "cmdecho" 0)
(setvar "blipmode" 0)
(setvar "osmode" 0)
(setq cl (getvar"clayer"))
(if (not (tblsearch "LAYER" "rcloud"))
(command "layer" "m" "rcloud" "c" "2" "rcloud" "")
(command "layer" "s" "rcloud" "")
;;--------real program starts here!
(Setq INC_ANGLE 110)
(if (and
(/= "" (getcfg "AppData/AC_Bonus/Revcld_Bulge"))
(/= nil (getcfg "AppData/AC_Bonus/Revcld_Bulge"))
(setq ARC_DIST (atof (getcfg "AppData/AC_Bonus/Revcld_Bulge")))
(if (= (getvar "DIMSCALE") 0)
(setq ARC_DIST 0.375)
(setq ARC_DIST (* 0.375 (getvar "DIMSCALE")))
);end if
(prompt (strcat "\nArc length set at " (rtos ARC_DIST 2 3)))
(setq plwid (getvar"plinewid"))
(setvar "plinewid" (* (getvar"dimscale")0.0078)); use for wider than zero pline width
; (setvar"plinewid" 0.0); use for zero pline width
(setq om (getvar"orthomode"))
(setvar "orthomode" 0)
(initget "Arc")
(setq LAST_PT (GetPoint "\nArc length/<Pick cloud starting point>: "))
(if (= LAST_PT "Arc")
(initget 6)
(setq TMP (getdist (strcat "\nArc length <" (rtos ARC_DIST 2 3) ">: ")))
(if TMP
(Progn
(setq ARC_DIST TMP)
;R14 method of saving variable values
(setcfg "AppData/AC_Bonus/Revcld_Bulge" (rtos ARC_DIST))
(setq LAST_PT (getpoint "\nPick cloud start point: "))
) ;;end STR "RADIUS" test
(if LAST_PT (progn ;;start up the cloud generator...
(setq START_PT LAST_PT
SAVED_EN (entlast))
(Prompt "\nGuide crosshairs along cloud path...")
(Command
"_.pline" ;draw cloud as a polyline on current layer
LAST_PT
"_a" ;specify arc option
"_a" ;specify angle option
INC_ANGLE ;included angle
)) ;end IF LAST_PT
(While LAST_PT ;;as long as we have a last point value,
(Setq NEXT_PT (GrRead 1) ;;real time read
READTYP (car NEXT_PT)
(if (or (= 5 READTYP) (= READTYP 3)) ;;read a position or a pick?
(setq NEXT_PT (cadr NEXT_PT))
(If (or (> (Distance LAST_PT NEXT_PT) ARC_DIST) (= READTYP 3))
(Progn
(Command NEXT_PT "_a" INC_ANGLE)
(Setq LAST_PT NEXT_PT)
(If (>
(Distance START_PT NEXT_PT)
(Progn
(Command START_PT "_cl")
(Setq LAST_PT Nil)
(prompt "\nCloud finished.")
(prompt "\nMove the pointer to draw the cloud")
);End if
);End while
(setvar "cmdecho" ce)
(setvar "blipmode" blp)
(setvar "osmode" osm)
(setvar "orthomode" om)
(setvar "plinewid" plwid)
(Princ)
(Defun c:RCHELP (/)
(prompt " The Revision Cloud program draws a user specified bulge pline\n")
(prompt " along the path of the crosshairs. To close the cloud, \n")
(prompt " simply return to the starting point\n")
(prompt " The cloud arc length can be specified in the beginning, with keyboard input\n")
(prompt " by specifying A for Arc, entering a length, or picking two pts.\n")
(textscr)
(Prompt " REVCLOUD loaded. Type REVCLOUD to draw Revision Cloud,\n")
(prompt " to close, return to starting point. For additional Help - RCHELP")
(Princ)
