Author Topic: Retrieving data from an Access file  (Read 3025 times)
Amsterdammed
« on: November 10, 2005, 09:49:47 AM »
Hello everybody.
A time ago I learned here how to access data in vlisp from Excel. What would be the code for getting data from an MSAccess file?
Thanks in Advance
Bernd
Re: Retrieving data from an Access file
« Reply #1 on: November 10, 2005, 10:03:11 AM »
The Visual LISP Developers Bible – 2003 Edition ( David Stein ) might have a hint or two.
Amsterdammed
« Reply #2 on: November 10, 2005, 05:49:54 PM »
Mark,
Sorry, Google didn't bring up the bible. Do you have any links or ideas where i can get that info?
TIA
Bernd
Bob Wahr
« Reply #3 on: November 10, 2005, 06:15:22 PM »
It used to be www.dsxcad.com but is gone now.  If I remember correctly it was given freely with desire by him that anyone who wanted a copy could have one.  I believe that I have it at home.  He might have changed his mind though.
TR
« Reply #4 on: November 10, 2005, 06:16:05 PM »
Try this
Bob Wahr
« Reply #5 on: November 10, 2005, 06:23:08 PM »
big help
Not sure if it's still valid but you might try emailing him davidmstein at yahoo.com
« Reply #6 on: November 10, 2005, 06:33:02 PM »
This is what I thought, too. I've placed it in the lilly pond for download.
You can also still see most of David Stein's site at archive.org
« Reply #7 on: November 10, 2005, 06:59:38 PM »
Now that the Developer Bible is taken care of I'll state that  there is nothing in it regarding Access.
However, here's a big help for Amsterdammed: Mr. Jon Fleming is the biggest expert in this field that I'm aware of. His WEB SITE has some excellent stuff for accessing Access databases. Go there and be amazed..... :-)
Bob Wahr
« Reply #8 on: November 10, 2005, 07:07:11 PM »
Thanks for the link Jeff.  I always forget about archive.org.  It was fun poking around.  Followed a link on dsxcad to cad encoding then the link the the vbdesign forums...Ahh the good old days.  Fun little trip down memory lane.
« Reply #9 on: November 10, 2005, 07:50:40 PM »
I agree with Jeff's comment regarding Jon Fleming's site.
Give yourself some time to absorb it all.
« Last Edit: November 11, 2005, 07:55:39 AM by Kerry Brown »
V-Man
« Reply #10 on: November 11, 2005, 07:34:09 AM »
Here, this will get you started.
« Reply #11 on: November 11, 2005, 08:01:10 AM »
I used to put all my DAO / ADO code in an ActiveX DLL and then call same from Visual LISP. Worked very well for years (and still does). But about a year ago I took a run at translating portions of the book "Access Database Design & Programming" to Visual LISP. To my surprise it didn't take much effort and even more surprising, execution was very fast. While translation may not appeal to you right at this moment, tuck the idea away in your pocket -- you learn very interesting things going that route. An aside, the noted book has proven very valuable to me, though admittedly, I'm a book hound (Collyer brothers anyone?).
Amsterdammed
« Reply #12 on: November 11, 2005, 02:40:41 PM »
Michael,
Well, it looks good to me. But right now i  just want to access some data from one file belonging to an other Application we work with. But I guess i got enough information on the links in threat.
Thanks, Bernd
« Reply #13 on: November 11, 2005, 03:17:57 PM »
Yep, to "tuck away" as noted -- some things are for a longer burn.
