Here's one that R. Robert Bell has posted numerous times on the Adesk forums.
Written by: R. Robert Bell
Purpose: Allows the user to enter a wildcard string to keep any matching filters.
Sample string: "`#*,MW*" will keep all filters beginning with a "#" or "MW"
Copyright © 2004 by R. Robert Bell
(defun rrbI:LayerFiltersDelete (strKeepWC / objXDict)
;; This function insures that an Extension Dictionary exists, and works on both locations for layer filters
(vl-load-com) ; load ActiveX if needed
(vl-catch-all-apply ; trap error if no extension dictionary
(function
(lambda ()
(setq objXDict (vla-GetExtensionDictionary ; bind dictionary to variable
(vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))))))
(cond (objXDict ; if the extension dictionary exists
(or ; use OR to return T for success
(rrbI:DeleteAllXRecs objXDict "ACAD_LAYERFILTERS" strKeepWC) ; pre-2005 layer filters
(rrbI:DeleteAllXRecs objXDict "AcLyDictionary" strKeepWC))))) ; 2005 layer filters
(defun rrbI:DeleteAllXRecs (objXDict dictName strKeepWC / objDict i)
;; This function performs the chore of deleting each filer that doesn't match the wildcard
(vl-catch-all-apply ; trap errors
(function
(lambda ()
(setq objDict (vla-Item objXDict dictName)) ; get layer filters dictionary
(vlax-for objXRec objDict ; loop thru all XRecords in the dictionary
(cond ((not (and strKeepWC (wcmatch (vla-Get-Name objXRec) strKeepWC))) ; if deleting all filters, or current doesn't match wildcard
(setq i (1+ (cond (i) ; increment counter
(0)))) ; initialize counter
(vla-Delete objXRec))))))) ; delete filter
(cond (i (princ (strcat "\n" (itoa i) " filters deleted."))))) ; if counter is bound, report number of filters deleted
(defun C:LFD (/ inpKeep)
;; Main command-line function
(setq inpKeep (getstring
"\nWildcard mask for filters to keep, or <Enter> to delete all: "))
(rrbI:LayerFiltersDelete (cond ((/= inpKeep "") inpKeep))) ; pass nil to subr if user hit <Enter>
(princ)) ; clean exit
