Author Topic: Question 31 goes here  (Read 7111 times)
« on: September 21, 2005, 01:40:05 PM »
How to compile a list of lisp files into a single fas file?
Re: Question 31 goes here
« Reply #1 on: September 21, 2005, 01:52:51 PM »
Add files via the 'LISP files to include' dialogue ...
« Reply #2 on: September 21, 2005, 01:56:12 PM »
Ok .. my response would be why? ... but just in case ... two methods I can use to do just such a thing ...
Combine the various lisp files into one single file then compile or add the other lisp files as resources to the main lisp in the fas ...
« Reply #3 on: September 21, 2005, 01:57:32 PM »
Yep, if you go that route you can command line compile via (vlisp-compile ...).
LE
« Reply #4 on: September 21, 2005, 01:58:57 PM »
Nope, that would produce various fas - we are looking for a way to get a single fas file and add any lisp file from any location, including path or part of the support paths....
LE
« Reply #5 on: September 21, 2005, 02:00:58 PM »
 :roll:
It is just a question on what to use something to produce a single fas.... as we can package into a vlx extension....
« Reply #6 on: September 21, 2005, 02:05:47 PM »
Well, considering that FAS is considerably less secure than VLX that is why I stated my comment in that manner.
I prefer breaking up my functions into multiple FAS files (as many as I can) then compile the multiple FAS files into a VLX, seperate namespace and optimized.
« Reply #7 on: September 21, 2005, 02:08:35 PM »
I'm with Keith, I never use fas files. Enlighten for amusement please.
« Reply #8 on: September 21, 2005, 02:09:28 PM »
Never mind.
LE
« Reply #9 on: September 21, 2005, 02:19:58 PM »
And what is the function usage for that?
« Reply #10 on: September 21, 2005, 05:00:27 PM »
(vlisp-compile-list 'st
                    (list "file-a" "file-b" "file-c")
                    "c:\\VL-Compiled\\testCompile.fas"
LE
« Reply #11 on: September 21, 2005, 05:10:27 PM »
 :kewl:  yes....
Here are some info about others vlisp-xxx functions:
;; compile a list of lsp files into a single fas file
;; files do not required the .lsp extension or the path
;; as long they are inside of a support folder.
(vlisp-compile-list
  'st
  (list
    "dtt-general"
    "dtt-inifile"
    "odcl_GPoly")
  "c:\\GPoly.fas")
;; find a vlisp project
(vlisp-find-project "gpoly.prj")
;; "C:/Documents and Settings/Jose Rodriguez/Desktop/ui_gpoly/gpoly.prj"
;; make a lsp file into fas
;; same as function "vlisp-compile"
(vlisp-make-file-fas 'st "dtt-general")
;; make all lsp files into fas from a vlisp project
(vlisp-make-project-fas "gpoly.prj")
;; return a list of all fas files with path
;; made from a vlisp project
(vlisp-project-fas-list "gpoly.prj")
;;;("C:/Documents and Settings/Jose Rodriguez/Desktop/ui_gpoly/dtt-general.fas"
;;;  "C:/Documents and Settings/Jose Rodriguez/Desktop/ui_gpoly/dtt-inifile.fas"
;;;  "C:/Documents and Settings/Jose Rodriguez/Desktop/ui_gpoly/odcl_GPoly.fas")
« Reply #12 on: September 21, 2005, 06:00:30 PM »
Good stuff, thanks for sharing Mr. Esquivel.
« Reply #13 on: September 21, 2005, 08:24:23 PM »
Question: Who is Jose Rodriguez? Alter Ego?
LE
« Reply #14 on: September 21, 2005, 08:37:53 PM »
no problema....
Mr? Hey I am just 21..... hehe
