Author Topic: importing survey data  (Read 3338 times)
dubb
« on: September 09, 2005, 05:22:34 PM »
im trying to import some survey data on land desktop. how can this be done
this is my file
   602   2203039.3154729   6050435.4859292        48.2460000
   603   2203022.0496362   6050431.0719577        47.3570000
   604   2203004.9154250   6050421.1243283        47.3480000
   605   2202970.1582547   6050400.8506090        47.3660000
   606   2202936.2576416   6050381.1720711        47.3800000
   607   2202921.2195044   6050372.2840040        47.3850000
   608   2202901.8002112   6050360.9835691        47.3630000
i have done this once before but i forgot how...can somebody help me out.
thanks in advance.
Re: importing survey data
« Reply #1 on: September 09, 2005, 05:27:00 PM »
Hint: It's under Points->Import/Export Points
dubb
« Reply #2 on: September 09, 2005, 06:05:28 PM »
thanks jeff....i did that but then all the points ended up on one location. it seemed like everything was on top of eachother. and then i did it again only that time i used different options and it doesnt draw anything on the screen. is there a tutorial guide for this?
Dinosaur
« Reply #3 on: September 09, 2005, 06:22:56 PM »
Are you sure that you are trying to use the correct file format?  It looks like the option you would use would be a column delineated file with point number, northing, easting (or easting, northing - should be obvious in your drawing), and elevation with no description.  If using that doesn't work, I just noticed extra spaces between you 2nd coordinate column and the elevation - that may throw things off.
dubb
« Reply #4 on: September 09, 2005, 06:29:35 PM »
thanks that was what  i was suspecting....i try comma delineated (spell-check) be right back...thanks
Dent Cermak
« Reply #5 on: September 12, 2005, 04:46:01 PM »
PNEZ Space Delimited file please. In the sample you show above, there are no commas, so comma delimited won't work.
« Last Edit: September 13, 2005, 08:39:27 AM by Dent Cermak »
dubb
« Reply #6 on: September 13, 2005, 04:02:27 PM »
thanks dent....i failed to look at that certain section in the pulldown. so now i have my survey data in. thanks folks.
Dent Cermak
« Reply #7 on: September 14, 2005, 12:51:32 PM »
  8-) HEY!! I got one right!!  :mrgreen: (Dent doing the "Fat Man Dance".....boompa.......boompa.......boompa......snik!!) :lol: :lmao:
« Last Edit: September 14, 2005, 12:53:11 PM by Dent Cermak »
