murphy it's working swwwwweet
Thank you. Glad you like it
i'll have to play around with it a bit. a couple questions:
my cells are not merged how do i get them to merge
You select the cells you want to merge, right click and select Format Cells.
On the Alignment tab at the bottom you will see a check box labeled Merge. Check it.
can you draw multiple sheets from excel as seperate schedules
Yes you can.
can you have double lines underneath borders like excel
It will not actually draw two lines. It will change line thickness per what it is set in Excel. That is an idea I will add to the wish list.
does anyone have example settings they have customized i can look at as an example.
The settings that are in there are my working settings. They are for drawing schedules at full scale so that they can either be drawn in Paper space or in Model space and use a 1:1 viewport scale.
