Author Topic: Help Using ENTNEXT to Update Block Attribute  (Read 3973 times)
tcdan
« on: July 29, 2005, 07:26:03 PM »
OK - so I didn't search this time to see if this question has been covered.
1. insert block
2. (setq en (entget (entlast)))
3. use ENTNEXT to cycle through attributes which I thought followed the main entity: (setq en (entget (entnext en)))
But when I try to use ENTNEXT, I get an error followed by the contents of the elist previously returned by entget:
; error: bad argument type: lentityp ((-1 . <Entity name: 7ecbe9e0>) (0 .
"INSERT") (330 . <Entity name: 7ef8bcb8>) (5 . "24214") (100 . "AcDbEntity")
(67 . 0) (410 . "Model") (8 . "EASMENTS") (6 . "Continuous") (100 .
"AcDbBlockReference") (66 . 1) (2 . "NORTHA") (10 6204.67 24007.3 0.0) (41 .
25.0) (42 . 25.0) (43 . 25.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 .
0.0) (210 0.0 0.0 1.0))
« Reply #1 on: July 29, 2005, 07:35:24 PM »
You must supply the ENAME for entnext:
(setq ent (entlast))
(setq entlist (entget ent))
(setq ent (entnext ent))
;...etc. usually wrapped in a (while) loop
tcdan
« Reply #2 on: July 29, 2005, 07:49:29 PM »
Oh yeah, that makes sense.
I don't really understand the way entget uses ENAME's and what an ename really is and why you then you have to convert them to use them with VLA- functions and all that. . .
I'm guessing the ENAME is the unique identifier of the object in ACAD's database - kind of like a pointer - that is saved in the drawing and accessible from session to session of CAD.
« Reply #3 on: July 29, 2005, 08:09:50 PM »
Quote from: tcdan
The pointer part is correct, however the ename value changes from session to session. The only thing that stays the same is the entity's handle. The ename and vla-objectid are both recreated, AFAIK, every time the drawing is opened. (Although I have never run tests to verify this, I'm just repeating what I've read)
BTW, you CAN use (entnext) with the list returned by (entget)....you just need to do the entnext on the ename......
(setq ent (entnext (cdr (assoc -1 ent)))) should do it.
« Reply #4 on: July 29, 2005, 08:19:41 PM »
ObjectID's do change session to session.
tcdan
« Reply #5 on: July 29, 2005, 08:22:16 PM »
should do it.
That's pretty nifty. . . yeah - I like that.  Thanks jeff!
tcdan
« Reply #6 on: July 29, 2005, 08:24:57 PM »
Whoa man - nice emoticon.  Makes you look like a know it all :)
Did you insert that or attach it as an image or what
(or is it a secret)?
tcdan
tcdan
« Reply #8 on: July 29, 2005, 08:27:17 PM »
Could you clarify what that is?
« Reply #9 on: July 29, 2005, 08:41:11 PM »
The handle is a guarenteed unique, sequentially assigned hexidecimal number.
PS: Not a know it all, just a knurd havin' fun.
:cheesy:
tcdan
« Reply #10 on: July 29, 2005, 09:04:53 PM »
I can definitely appreciate that
« Reply #11 on: July 30, 2005, 01:36:11 PM »
And to further clarify the handle, it is stored as DXF code 5. So every time you (entget) an object you can extract it's handle from (assoc 5 ent) and be certain that it is the same from session to session. It even gets saved when exporting to a DXF file.
daron
« Reply #12 on: August 01, 2005, 07:36:32 AM »
Of course, it gets changed if you happen to wblock it out.
