Author Topic: Quick question -- mhatch.lsp  (Read 4020 times)
Kate M
« on: July 29, 2005, 11:04:01 AM »
I picked this up from the freebies section at dotsoft.com, but I'd like it to prompt me for the hatch pattern -- or at least use the "last used" pattern -- rather than default to solid.
(defun c:mhatch ()
  (setq cmdecho (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command "UNDO" "G")
  (setq sset (ssget '((-4 . "<OR")(0 . "POLYLINE")(0 . "LWPOLYLINE")(-4 . "OR>"))))
  (if sset
      (setq num (sslength sset) itm 0)
      (while (< itm num)
        (setq hnd (ssname sset itm))
        (command "_HATCH" "_S" hnd "")
        (setq itm (1+ itm))
      (command "_DRAWORDER" sset "" "_F")
  (command "UNDO" "E")
  (setvar "CMDECHO" cmdecho)
I'm pretty sure I have to replace the "_S" with something else, but I couldn't figure out what...
Thanks guys. :-)
David Hall
  • Automatic Duh Generator
« Reply #1 on: July 29, 2005, 11:15:22 AM »
I think the S is for select objects,  was solid your last pattern used?
Kate M
« Reply #2 on: July 29, 2005, 11:17:27 AM »
Ah, that makes sense about the S -- but no, SOLID was not the last pattern used. The description on dotsoft says it creates "independent solid fills"...
David Hall
« Reply #3 on: July 29, 2005, 11:22:34 AM »
I think I have it figured out.  what pattern did you want?
Kate M
« Reply #4 on: July 29, 2005, 11:24:02 AM »
Either the last one used, or a prompt, if that's possible...
David Hall
« Reply #5 on: July 29, 2005, 11:27:40 AM »
Im no guru at LISP but this is what I was able to get to
(defun c:mhatch ()
  (if sset
      (while (< itm num)
        (command "_HATCH" "p" "ANSI31" 1.0 0 "_S" hnd "")
        (setq itm (1+ itm))
I edited the line (command "_Hatch     to add a P for properties and pick Ansi31, Scale 1 , and Rotation 0.  Hope this helps
« Reply #6 on: July 29, 2005, 11:29:27 AM »
For the last one used, just delete the _S make sure the two double quotes remain, though. The _S is indicating to use a Solid fill, a simple return uses the last, or default if none have been used in this session, pattern used.
Oops...nevermind. I should check the entire command line first....... :oops:
David Hall
« Reply #7 on: July 29, 2005, 11:30:17 AM »
It defaults to last one used, once it has been set.  I am not sure how to ask the user, because they would need to know name/scale/rotation.
David Hall
« Reply #8 on: July 29, 2005, 11:31:21 AM »
Quote from: Jeff_M
Are you sure?  I steped through it at the command line, and it "looked" like that was for select object...
« Reply #9 on: July 29, 2005, 11:40:43 AM »
Quote from: CmdrDuh
About that portion, yes. However, removing the solid adds the options for scale & rotation.
_HATCH
Enter a pattern name or [?/Solid/User defined] <ANSI31>:
The S would mean you want a Solid hatch
« Reply #10 on: July 29, 2005, 11:51:38 AM »
Give this a whirl.....
(defun c:mhatch (/ cmdecho hnd hpat itm num sset)
  (if sset
      (while (< itm num)
(setq hpat (getstring (strcat "\nHatch pattern<" (getvar "hpname") ">: ")))
(command "_.hatch" hpat 1.0 0.0 hnd "")
        (setq itm (1+ itm))
David Hall
« Reply #11 on: July 29, 2005, 11:53:02 AM »
Quote from: Jeff_M
_HATCH
I can get _hatch to work.  It keeps loading the dialog box.  2006 here
Kate M
« Reply #12 on: July 29, 2005, 11:53:15 AM »
Ah, so that's why it crashed when I just took out the _S and left the quotes...trying again...
That's it! Cool beans.
Revised line (so it uses the previously-used pattern, scale, and rotation):
(command "_HATCH" "" "" "" hnd "")
Thanks for all the help :D
TJAM51
« Reply #13 on: July 29, 2005, 02:24:53 PM »
try these out......
;;;Misc hatch routines
;;;    Hatch Between two parallel lines
;;;  DH-2line places hatch between two parallel lines
;;;  Creates ANSI37 hatch 90 deg
(defun C:DH-2line (/ usercmd ss er e1 e2 p1 p2 p3 p4 xp1 xp2 xp3 xp4 yp1
      yp2 yp3   yp4 ang   HS RB)
  (setq   usercmd   (getvar "CMDECHO")
   ss   nil
   er   nil
   HS   "" ; Hatch Scale
   RB   "N" ; Retain Border
  (while (not ss)
    (prompt "\nSelect two parallel lines to hatch")
    (setq ss (ssget)) ;  ":S"  may be used
    (Cond
      ((equal ss nil)
       (setq er "Nothing selected:")
      ((< (sslength SS) 2)
       (setq er "too few lines selected.")
      ((> (sslength SS) 2)
       (setq er "too many lines selected.")
      (T
       (setq e1 (entget (ssname ss 0)))
       (setq e2 (entget (ssname ss 1)))
       (if (and   (= (cdr (assoc 0 e1)) "LINE")
      (= (cdr (assoc 0 e2)) "LINE")
    (progn ; Both are LINES
      (setq p1 (cdr (assoc 10 e1)) ; Get end points of lines
       p2 (cdr (assoc 11 e1))
       p3 (cdr (assoc 10 e2))
       p4 (cdr (assoc 11 e2))
      (setq xp1 (car p1) ; get x & y values of end points
       xp2 (car p2)
       xp3 (car p3)
       xp4 (car p4)
       yp1 (cadr p1)
       yp2 (cadr p2)
       yp3 (cadr p3)
       yp4 (cadr p4)
      ; Correct for cases where two points are not exactly equal (+/- .1)
      (Setq xp1 (if (equal xp1 xp2 0.1) xp2 xp1)) ; make exactly equal
      (Setq xp3 (if (equal xp3 xp4 0.1) xp4 xp3)) ; make exactly equal
      (Setq yp1 (if (equal yp1 yp2 0.1) yp2 yp1)) ; make exactly equal
      (Setq yp3 (if (equal yp3 yp4 0.1) yp4 yp3)) ; make exactly equal
      (if (or (> xp1 xp2) (and (= xp1 xp2) (> yp1 yp2))) ;  Swap ends
        (setq px p1 ; make starting ends the same
         p1 p2 ; by swaping ends
         p2 px
      (if (or (> xp3 xp4) (and (= xp3 xp4) (> yp3 yp4)))
        (setq px p3 ; make starting ends the same
         p3 p4 ; by swaping ends
         p4 px
      (setq ang (* 0.0 (/ (+ (angle p1 p2) (* pi 0.5)) pi))) ; Hatch @ 0 deg to line
      (setq pi2 (* pi 2)
       a1  (angle p1 p2) ; check for >= 2pi angle, set to 0 or correct to < 2pi
       a1  (if (equal a1 pi2 0.0001) 0 (if (> a1 pi2) (- a1 pi2)a1))
       a2  (angle p3 p4)
       a2  (if (equal a2 pi2 0.0001) 0 (if (> a2 pi2) (- a2 pi2)a2))
      (if (not (equal a1 a2 0.1)) ; (margin +/- 0.1 inch)
        (setq er "lines are not parallel.")
      ; Lines OK to Hatch
        (command "_.hatch" "" HS ang "" RB p1 p2 p4 p3 "close" "" )
      ) ; endif
    ) ;end progn
    (setq er "one or both item(s) not a LINE.")
       ) ; endif
      ) ; end (T)
    ) ; end cond
  ) ; end  while
  (if (/= er nil)
    (alert (strcat "ERROR: " er))
  (setvar "CMDECHO" usercmd)
) ; end defun
(Princ)
;;;    Hatch- three point
;;;  DH3 uses points picked for three Corners, long side then width
(defun C:dh3   (/ p1 p2 p3 p4 hs rb ang usercmd )
  ;Make 2D point from 3D point
  (defun 3dP->2dP (3dpt) (list (car 3dpt) (cadr 3dpt)))
  (setq usercmd (getvar "CMDECHO"))
  (prompt "\nPick boundry points to hatch")
  (setq   p1  (getPoint "\nPick first point:")
   p2  (getPoint p1 "\nPick along Pipe first:")
   p3  (getPoint p2 "\nPick across Pipe:")
   p1  (3dP->2dP p1)
   p2  (3dP->2dP p2)
   p3  (3dP->2dP p3)
   p4  (polar p1 (angle p2 p3) (distance p2 p3))
   HS   30      ; Hatch Scale
   ang (* 180.0 (/ (+ (angle p1 p2) (* pi 0.5)) pi))
(command "_.hatch" "" "" ang "" RB p1 p2 p3 p4 "close" "" )
(Princ)
;;;    Hatch - Unlimited points
(defun c:DH   (/ hs ang usercmd)
  (prompt "\nDraw a polyline boundry to hatch, Enter when done.")
  (setq   hs "" ; Hatch Scale
   ang 0 ; Hatch angle
   (command "_.hatch" "" HS ang "" "n")
); end defun
;;; Hatch - Creates separate hatch with several objects
(defun c:mhatch (/ sset idx hnd cmdecho)
  (setq sset
         (ssget
           '((-4 . "<OR") (0 . "POLYLINE") (0 . "LWPOLYLINE") (-4 . "OR>"))
  (if sset
      (command "UNDO" "_begin")
      (setq idx (sslength sset))
      (while (>= (setq idx (1- idx)) 0)
        (setq hnd (ssname sset idx))
        (command "_.hatch" "" "" "" hnd "")
      (command "UNDO" "_end")
;;; Hatch- Quick pick hatch command
(defun c:h (/ ss)
    (setvar "cmdecho" 0)
    (prompt "\n*** Select objects for Hatch & press [Enter] ")
    (if (and
            (setq ss (ssget))
            (> (sslength ss) 0)
        (command "hatch" "" "" "" ss "")
;;; Hatch - Matches the properties of existing hatches (sets only)
;;  Match properties of hatch pattern selected
;;  Set system variables to match
(defun c:hs (/ ent elist lay colr)
  (if (setq ent (entsel))
      (setq elist (entget (car ent)))
      (if (= (cdr (assoc 0 elist)) "HATCH")
          (command "_undo" "_begin")
          (setq lay (cdr (assoc 8 elist)))
          (setq colr (cdr (assoc 62 elist)))
          (setvar "hpname" (cdr (assoc 2 elist)))
          (setvar "hpang" (cdr (assoc 52 elist)))
          (if (or (= (substr (getvar "hpname") 1 2) "_U")
                  (= (substr (getvar "hpname") 1 1) "U")
              (if (= (cdr (assoc 78 elist)) 2)
                (setvar "hpdouble" 1)
              (if (= (cdr (assoc 78 elist)) 1)
                (setvar "hpdouble" 0)
              (setvar "hpspace" (cdr (assoc 41 elist)))
            (setvar "hpscale" (cdr (assoc 41 elist)))
          (command "_layer" "s" lay "")
          (if (null colr)
            (setvar "cecolor" "256")
            (setvar "cecolor" (itoa (cdr (assoc 62 elist))))
          (command "_undo" "_end")
          (if c:r
            (c:r)
            (redraw)
        (prompt "\nSelection is not a hatch")
    (prompt "\nNothing selected")
;;;Hatch - Matches existing hatch and allows user to pick new object
(defun c:mh (/ ocol olay col ent lay hat sca rot po)
  (setq ocol (getvar "cecolor"))
  (setq olay (getvar "clayer"))
  (setq oosn (getvar "osmode"))
  (setvar "osmode" 0)
  (if (setq ent (entsel "\nSelect a hatch pattern to copy."))
      (setq ent (entget (car ent)))
      (if (= (cdr (assoc 0 ent)) "HATCH")
     (setq lay (cdr (assoc 8 ent)))
     (setq hat (cdr (assoc 2 ent)))
     (setq sca (cdr (assoc 41 ent)))
     (setq rot (cdr (assoc 52 ent)))
     (setq rot (* rot (/ 180 pi)))
     (setq col (cdr (assoc 62 ent))) ; may return nil
       ((or (= col "BYLAYER") (= col "BYBLOCK"))
        (setvar "cecolor" col)
       ((= (type col) 'int)
        (setvar "cecolor" (itoa col))
     (command "layer" "s" lay "")
     (initget "s") ; this allows numbers to be entered
     (setq   po
       (getpoint "\nSelect Internal Point or (S)elect Objects:")
     (if (= (type po) 'list)
       (command "-bhatch" po "p" hat sca rot "")
       (if   (setq po (ssget)) ; allow one choice only
         (command "-bhatch" "s" po "" "p" hat sca rot "")
         (prompt "\nNothing selected.")
   (prompt "\nSelection was not a hatch.")
  (setvar "clayer" olay)
  (setvar "cecolor" ocol)
  (setvar "osmode" oosn)
;;; Hatch - 2-point hatch
(DEFUN C:2PHATCH ()
  (SETVAR "CMDECHO" 0)
  (SETQ
    X1 (GETPOINT "\nPick 1st corner:")
    Y2 (GETCORNER X1
       "\nPick opposite corner: ")
    LEN1 (DISTANCE X1 Y2)
    ANG1 (ANGLE X1 Y2)
    X2 (POLAR X1 0.0
       (* LEN1 (COS ANG1)))
    Y1 (POLAR Y2 PI
  (command "_.hatch" "" "" "" "" "n" X1 X2 Y2 Y1 "close" "")
  (SETVAR "CMDECHO" 1)
  (PRINC)
;;; Hatch - 2-point circular
(defun c:cdh ( )
  (command "osmode" "16")
  (command "circle" "2p" pause pause)
  (command)(command)
  (command "Hatch" "" pause 0 "L" "" "erase" "P" "")
  (command "osmode" "0")
;;; Hatch - Pick internal point
(defun c:hI (/ sSet *error*)
(defun *error* (msg)
(setvar "cmdecho" 1)
); end *error*
(setq ent1 (getpoint "*** Select POINT for Hatch "))
(command "_.-bhatch" ent1 "" "")
(while (= 1 (getvar "cmdactive"))
(command pause)
); end while
(command "")
daron
« Reply #14 on: July 29, 2005, 02:31:20 PM »
Anybody ever wonder why formatting tags like [code ] are so important? Here's an example:
Please edit your code with code tags TJ.
