Author Topic: Can this happen  (Read 2833 times)
TJAM51
Can this happen
« on: July 29, 2005, 07:51:45 AM »
If I have a layer in a drawing is there anyway I can lock the layer and keep others from unlocking the same layer?
Dinosaur
Can this happen
« Reply #1 on: July 29, 2005, 08:15:01 AM »
The only way I know of to do this is with privelges within Autodesk Map.
TJAM51
Can this happen
« Reply #2 on: July 29, 2005, 09:06:53 AM »
Could you enlighten me on this process?
M-dub
Can this happen
« Reply #3 on: July 29, 2005, 09:10:44 AM »
[guess]
Reactor :?:
[/guess]
Dinosaur
Can this happen
« Reply #4 on: July 29, 2005, 09:15:08 AM »
If you have Autodesk Map, you can log in as "SUPERUSER" and assign individual users permission to work with and save only selected layer groups within a single drawing.  This allows an entire team to work on a single drawing file at the same time and permits the "superuser" to deny access to any given element.
daron
Can this happen
« Reply #5 on: July 29, 2005, 09:15:31 AM »
I'd think you could set up something that looked at the username (loginname) on the computer and if it didn't match your name it would ^REACT^ by relocking that layer. Probably better to do this in vba.
TJAM51
Can this happen
« Reply #6 on: July 29, 2005, 09:20:25 AM »
Ok...I do not anything about reactors and I am not familiar with Autodesk Map. I looked at the help file and all it gave me information on was Qselect.......in the dark hear...anyone have a flashlight.....thanks
