I might actually beable to help you on this one.
***MENUGROUP=SMW-CHI
***POP1
[&Title Blocks...]$I=SMW-CHI.image_titleblock $i=*
***IMAGE
**IMAGE_TITLEBLOCK
[Title Blocks]
[Slides(ATT-8511,Attributes 8.5x11)]^C^C_-layer;set;0;;-insert;"C:/CHI-CUSTOMCAD/title blocks/ATT-8511" \;;;
[Slides(Att-8511L,Attributes 8.5x11L)]^C^C_-layer;set;0;;-insert;"C:/CHI-CUSTOMCAD/title blocks/Att-8511L" \;;;
[Slides(ATT-1117,Attributes 11x17)]^C^C_-layer;set;0;;-insert;"C:/CHI-CUSTOMCAD/title blocks/ATT-1117" \;;;
[Slides(Att-3042,Attributes 30x42)]^C^C_-layer;set;0;;-insert;"C:/CHI-CUSTOMCAD/title blocks/Att-3042" \;;;
[Slides(Att-3444,Attributes 34x44)]^C^C_-layer;set;0;;-insert;"C:/CHI-CUSTOMCAD/title blocks/Att-3444" \;;;
[Slides(Att-3648,Attributes 36x48)]^C^C_-layer;set;0;;-insert;"C:/CHI-CUSTOMCAD/title blocks/Att-3648" \;;;
This is code that I use in my setup, its only part of it but I didnt want to post like 6 pages of this stuff.
Here is how the format works.
*** IMAGE_(what ever you name your variable)
[Name of the GUI (it will show up in the top left corner)]
This is where it gets a bit confusing so I will try to explain it in steps...
1. Where I have
[Slides
this is the name of the SLB file that holds all the SLD files.
2.
(ATT-8511,Attributes 8.5X11)]
this is stating that "ATT-8511" is the SLD file name, "Attributes 8.5X11" is what the Description is of that SLD file. This discription will show up in the description box of the GUI.
3.
This is just like a button code. It says where to insert the file from and what to do when it is Inserted, basically "\" = Pause ";" = Enter stroke.
// AutoCAD menu file - S:\MENU\Wynn-Menu.MNU
***MENUGROUP=Titleblocks
***POP20
**Titlelbocks
[TitleBlocks]
[TITLEBLOCK PART 1]$I=TitleBlocks.Wynn-TB $I=*
[TitleBlock Part 2]$I=TitleBlocks.Wynn-TB2 $I=*
***TOOLBARS
***IMAGE
**Wynn-TB
[Wynn Engineering Titleblocks]
[WE-CALC-85x11]^C^C-insert WE-CALC-85x11 \;;\
[WE-TB-11x17]^C^C-insert WE-TB-11x17 \;;\
[WE-TB-24x36]^C^C-insert WE-TB-24x36 \;;\
[WE-TB-30x42]^C^C-insert WE-TB-30x42 \;;\
[WE-TB-36x48]^C^C-insert WE-TB-36x48 \;;\
[WE-TB-85x1]^C^C-insert WE-TB-85x11 \;;\
[WE-TB-NORTH]^C^C-insert WE-TB-NORTH \;;\
[WE-TB-STAMP]^C^C-insert WE-TB-STAMP \;;\
[WE-TITLE-NORTH]^C^C-insert WE-TITLE-NORTH \;;\
**Wynn-TB2
[Wynn Engineering Titleblocks 2]
***MENUGROUP=
***POP50
**Commands
[Wynn-Menu]
[->Commands]
[&Break-Line]^C^Cbl;
[Change Multiple Text]^C^Ccht;
[Revision]^C^Crc;
[Snap-Angle]^C^Csa;
[Plot-Log]Plog
[Copy multiple]^C^Ccm;
[Fix Target](command "vbaload" "fix-target" "vbarun" "fixtarget")(princ)
[->Zoom]
[&Extents]'ze
[<-&Previous]'zp
[->->Send &Private Message To:]
[Bill]pm;BI;
[Bryan]pm;B;
[Bruce]pm;BR;
[Dawn]pm;d;
[Jack]pm;ja;
[Jennifer]pm;j;
[Jurek]pm;ju;
[Larry]pm;l;
[Marla]pm;m;
[Sharon]pm;sh;
[<-Souk]pm;s;
[->Change &Layer]
[S-&1]1;;
[S-&2]2;;
[S-&3]3;;
[S-&4]4;;
[S-&5]5;;
[&S-56]56;;
[S-&6]6;;
[S-&7]7;;
[S-&8]8;;
[<-S-&9]9;;
[->->Dimensions]
[Horiz/Vert]dl
[Aligned]dal
[Leader w/ Dot]ld
[leader w/ loop]ll
[<-<-2head Leader]span
[->->Setup]
[->->Plot 24x36]
[1"=1"]12436;
[1 1/2"=1'-0"]82436;
[1"=1'-0"]122436;
[3/4"=1'-0"]162436;
[1/2"=1'-0"]242436
[1/4"=1'-0"]482436;
[3/16"=1'-0"]642436;
[1/8"=1'-0"]962436;
[<-3/32"=1'-0"]1282436;
[->->Plot 30x42]
[1"=1"]13042;
[1 1/2"=1'-0"]83042;
[1"=1'-0"]123042
[3/4"=1'-0"]163042;
[1/2"=1'-0"]243042
[1/4"=1'-0"]483042;
[3/16"=1'-0"]643042;
[1/8"=1'-0"]963042;
[<-3/32"=1'-0"]1283042;
[->->Titleblock]
[<-Detail Grid]^C^Cgb;
// End of AutoCAD menu file - S:\WYNN-CAD\menu\Wynn-Menu.mnu
From your post here is what I think is wrong with it.
***POP20
**Titlelbocks
[TitleBlocks]
[TITLEBLOCK PART 1]$I=IMAGE_Wynn-TB $I=*
[TitleBlock Part 2]$I=IMAGE_Wynn-TB2 $I=*
***IMAGE
**IMAGE_Wynn-TB
[SILDELIBRARYNAME(SLIDENAME,DESCRIPTION)]^C^C-insert[b];[/b]WE-CALC-85x11 \;;\
**IMAGE_Wynn-TB2
[SLIDELIBRARYNAME(SLIDENAME,DESCRIPTION)]^C^C-insert;WE-TB-24x36 \;;\
In my Code I always but the **IMAGE stuff at the very end of the code.
I didnt go through all your code just the Image stuff.
Now your probably like "what the hell is a SLB file" well here you go.
Once the slides are created, you need to make sure that slidelib.exe is in C:\directory (the directory your slides are in)
As seen in the AutoCAD help file, go to dos prompt, and while in the directory, type:
dir *.sld /b > slidelist
Then, with that list in the same directory, type:
slidelib libraryname < slidelist
http://theswamp.org/phpBB2/viewtopic.php?t=2381&highlight=slidelib&sid=870e1dcbce04e4f069ef92ce538e33b7
Basically, Here is how mine is setup. I created a Directory on my C:\ drive for all my blocks and menus and custom stuff (for easiness...I will call it CADBLOCKS).
so..
C:\CADBLOCKS
I created all my Slides I wanted using the MSLIDE command. Took all though SLD files and placed them in a directory....
C:\CADBLOCKS\SLIDES
Once I did that I copied the SLIDELIB.EXE into that directory.
Opened DOS prompt, typed...
cd cadblocks\slides
<- this should take you to c:\cadblocks\slides
Then,
<- (slidelist will be basically a text file, with only the the SLD files listed (hence the *.sld))
Next,
slidelib Slides < slidelist
<- This will create a SLB file named Slides and place all the named files within the Slidelist file in the SLB file.
SO,
[Slides(SLIDENAME,Discription)]
<- It will look in the SLIDE.SLB file for the SLIDENAME and pull out the SLD file and make it viewable in the Imagebox
Now I have found that the IMAGE files (SLB and SLD) location needs to be in the support file search path under preferances or the Slides wont load.
If I get time I will try to go through your code and see if I can fix it. But I would suggest trying it on your own first so that you can learn it.
