Author Topic: 1.)arrangement list and 2.)how to get block biggest circle on block  (Read 390 times)
masao
hi~
1.)
how can i get this result?
select LWPOLYLINE arrangement it.
if x and y overlapping remove it.
2.)
if i use (ssget) select some INSERT(block and has some circle on it) , how can i get biggest circle and coordinate on block?
dwg has block
-------------------------------------Q1 code---------------------------------------------------
  1. (defun c:get_list()
  2.
  3. (setq osm (getvar "osmode"))
  4.
  5. (setq ss (ssget '((0 . "LWPOLYLINE"))))
  6.
  7. (if ss
  8.
  9.
  10. (setq i 0)
  11.
  12. (setq pt_list '())
  13.
  14.
  15. (setq obj (vlax-ename->vla-object (ssname ss i)))
  16.
  17. (vla-GetBoundingBox obj 'p1 'p2)
  18.
  19. (setq pt_list (cons (list (get_midpt (vlax-safearray->list p1) (vlax-safearray->list p2)) obj (vlax-safearray->list p1) (vlax-safearray->list p2)) pt_list))
  20.
  21. (setq i (+ i 1))
  22.
  23. );repeat
  24.
  25. (setq pt_list (vl-sort pt_list (function (lambda (e1 e2) (if (or (equal (cadr (car e1)) (cadr (car e2)) 1e1) (< (- (abs (- (cadr (car e1)) (cadr (car e2)) )) (abs (- (cadr (caddr e1)) (cadr (car e1)) )) (abs (- (cadr (caddr e2)) (cadr (car e2)) )) ) 0) ) (< (car (car e1)) (car (car e2))) (> (cadr (car e1)) (cadr (car e2))) )))))
  26.
  27. (setq k 1)
  28.
  29. (foreach pt pt_list
  30.
  31. (setq a3wp1 (caddr pt))
  32.
  33. (setq a3wp2 (cadddr pt))
  34.
  35. (setvar "osmode" 0)
  36.
  37. (command "rectangle" a3wp1 a3wp2)
  38.
  39. (setq obj (vlax-ename->vla-object (entlast)))
  40.
  41. (vlax-put obj 'color k)
  42.
  43. (setq k (+ k 1))
  44.
  45. );foreach
  46.
  47. );progn
  48.
  49. );if
  50.
  51. (setvar "osmode" osm)
  52.
  53. )
  54.
  55.
  56.
  57. (defun get_midpt(pt1 pt2)
  58.  (setq mx (/ (+ (car pt1) (car pt2)) 2))
  59.  (setq my (/ (+ (cadr pt1) (cadr pt2)) 2))
  60.  (list mx my)
  61. )
edit @kerry : add AutoLisp code formatting tag [code=cadlisp-7]
« Last Edit: July 12, 2024, 09:03:32 AM by masao »
