Author Topic: Help : I want to know block information in xref  (Read 638 times)
azrael
  • Mosquito
« on: June 30, 2024, 08:37:57 PM »
I want to know the information of blocks within an xrefed drawing, such as the block's name, insert point, etc. How can I obtain this information?
Re: Help : I want to know block information in xref
« Reply #1 on: July 01, 2024, 06:17:05 AM »
An xref is merely a specialised block reference whose block table record references the database in a separate drawing; as such, to obtain information about blocks within the xref drawing, you can simply iterate over the components of the block table record as you might for a standard block.
azrael
  • Mosquito
« Reply #2 on: July 02, 2024, 09:23:24 AM »
Are there any books or documents that can refer to the usage or explanation of functions that begin with vl- vla- vlx-, etc.?
I went to Autodesk and found the vla-get-blocks function, but the information didn't come up
« Reply #3 on: July 02, 2024, 10:21:29 AM »
There is tons of information in the help file.
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-BA470FE7-6488-4BC9-8FC8-ED93C32D86AA
azrael
  • Mosquito
« Reply #4 on: July 03, 2024, 01:55:23 AM »
Thank you for your answer
But isn't there a vla-reference like AutoLISP Reference
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-4CEE5072-8817-4920-8A2D-7060F5E16547
« Reply #5 on: July 03, 2024, 05:14:00 AM »
When you say "vla-" you're likely referring to the ActiveX interface exposed to Visual LISP - a reference for which may be found here:
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-A809CD71-4655-44E2-B674-1FE200B9FE30
